Metabox PA71-ESG First Impressions Review
Discussion in 'Reseller Feedback Forum' started by whambamsam, May 25, 2018.
  1. whambamsam
    whambamsam Notebook Enthusiast
    Just received my laptop earlier today; specs
    QHD120H LED w/ G-Sync
    i7-8750H
    1x16GB 2400MHz (I intend to add another stick)
    500GB 960 Samsung EVO
    1TB 7200RPM HDD
    Intel 9560 AC
    So far, a little disappointed - I'm upgrading from an ASUS G750 DB71 from 2013/2014, and though this is much slimmer and sleeker it is significantly noisier.
    I'm also a little concerned about the temps I'm getting - fired up PUBG and the CPU hit a peak of 95, GPU about 70+. Not sure if the high CPU temp is just the nature of the Coffee Lake CPUs being too much for the platform to handle?
    EDIT: Normal Usage temps (chrome with about 10 tabs, GOG downloading Witcher 3 in background, discord open, steam open) - 68 to 80C CPU, GPU steady at 45.
    Looking for some tips/pointers on how best I can set the laptop up to perform at its best.
  2. Danishblunt
    Danishblunt Guest
    Well it's a clevo so you basicially got barebones notebook which lacks finetuning in every aspect. I don't think you can do anything about the fan noise since fan control on clevos are nothing short of a disaster, the pathethic sound and and temps are normal.
    Best bet for you is to do some lapping, repasting and possibly a thermal pad.
  3. Mobius 1
    I don't think that any notebook come "fine tuned" nowadays
    oSChakal and Support.2@XOTIC PC like this.
  4. Danishblunt
    Danishblunt Guest
    True, but at least the software is working on some brands and most notebooks get fixed by simply repasting. Clevo just janks some software onto the notebook and prays that it runs. Speakers on clevo notebooks are hardwarewise not that terrible, sadly the crap software ruins it, no real control on clevo notebooks either. All you can do is mod heatsinks and get a cooling pad and it will still be way to loud.
  5. whambamsam
    @Danishblunt Looked at lapping and that looks way too dangerous for me...
    Happy to take the laptop somewhere for repasting and maybe installing thermal pads though.
    Do you guys have recommendations on stuff I should be running to make sure everything is set up? I'm very new to all of this.
  6. XMG
    XMG Company Representative
    Your GPU temps are normal, nothing out of the ordinary here. Your CPU temp is on the high side tbh, you shouldn't really be seeing more than 90C even in a full stress test.
    You shouldn't be concerned with fixing this yourself, you bought the laptop from a respected company so just contact them and point out that you're concerned about your CPU temps - I'm sure they will support you with this and can repaste or replace the heatsink if it's necessary for you.
  7. Danishblunt
    Danishblunt Guest
    Either send it in for a repaste, ask for repaste yourself and if it doesnt work after that RMA it.
  8. Support.2@XOTIC PC
  9. whambamsam
    I was told after doing tests with heavenly benchmark that my temps seem normal. I'm only getting spikes of high temps (over 90) during gaming, but it's inconsistent (temps vary quite wildly) so I can't pin down the issue.
    I've yet to try an undervolt, hoping someone could help me out there?
  10. Support.2@XOTIC PC
    What application are you using to monitor the temps when in game?
