Memory upgrade recommendation for fujitsu s6130?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Toshiniko, Nov 9, 2004.
  1. Toshiniko
    Toshiniko Newbie
    Hai all, i am thinking to upgrade my laptop memory of 512 mb. Any good recommendation for the brand? and what tipe? i was thinking about kingstone and corsair? will they work compatibly with the existing memory (256mb)from the factory? and how many percentages (roughly) will it increase my laptop performance (total ram 712mb)? thanx.
    cheers,
    Toshi
  2. Brian
    Brian Working at 486 Speed NBR Reviewer
    I like Crucial, but the other two you listed are also good. No, there will be no conflict, RAM doesn't have problems co-existing. As for performance increase, I can't offer a percentage, but I can tell you going from 256 to 712 will be a massive improvement.
    Editor in Chief http://www.bargainPDA.com and http://www.SPOTstop.com
  3. Toshiniko
    Toshiniko Newbie
    Ow ic, do u know what kind corsair series will fit with my s6130?
    cheers,
    Toshi
  4. Brian
    You need a pretty standard PC2700 chip.
  5. Toshiniko
    Toshiniko Newbie
    Is it the vs512sd333 type? or are there any other xms memory from corsair that will work on s6130?
    cheers,
    Toshi
  6. Toshiniko
    Toshiniko Newbie
    [:(] still no reply?? i happened to saw an article about the corsair xms CMXSD512-2700LL and i was wondering if it will work in the s6130? thanks alot for answering.
    cheers,
    Toshi
  7. Brian
    Yes, I think that's fine. I would suggest emailing them directly with specific questions.
