Memory Stick Pro - how to insert in memory
Discussion in 'Hardware Components and Aftermarket Upgrades' started by wildwolf, Aug 18, 2008.
  1. wildwolf
    wildwolf Notebook Enthusiast
    Have a dell Inspiron 1525 notebook with memory card reader, compatible with Memory Stick Pro - but i cannot figure out how to insert the memory stick into the memory card reader - an SD card slots in easily, but how do i to put the Sony stick in - it seems way too small for the slot?
    Bit of a mystery to me i'm afraid - any advice appreciated, thanks!
  2. D3X
    D3X the robo know it all
    Is it a Memory Stick Pro Duo?
    If it's the same as the black memory card, then you will need a memory stick adapter pictured above for it to work in your dell.
    If it's Memory stick Pro, which is the same length as the old blue memory stick. Just stick it in and it should work.
  3. wildwolf
    Thanks D3X - yes it is the Pro Duo. Once i saw the photo above, i remembered that i got the adaptor with my camera when i bought it - i had forgotten all about it! Many thanks for your quick response and the photo was really helpful.
