Memory: 16GB at 1333Mhz or 12GB at 1600Mhz
Discussion in 'Hardware Components and Aftermarket Upgrades' started by DVCal, Jun 20, 2012.
  1. DVCal
    DVCal Notebook Enthusiast
    What is better having 4 4GB 1333Mhz DDR3 RAM or 3 4GB 1600Mhz DDR3 Ram?
    Thanks
  2. KCETech1
    KCETech1 Super Moderator Super Moderator
    unless your big on benchmarking get 16gb. but alot of apps wont use either especially games, so know your software needs too
    3X 4 also means no dual channel on the second pair dropping speed
  3. Rishwin
    Rishwin Notebook Deity
    4x4gb 1333
  4. maverick1989
    maverick1989 Notebook Deity
    Like KCETech said, it depends. You cannot say that 4x4GB at 1333 is better without knowing OPs needs.
  5. sarge_
    sarge_ Notebook Deity
    Duh, it's a no brainer. 4x4gb 1333mhz is both faster and bigger than 3x4gb 1600mhz.
  6. HTWingNut
    HTWingNut Brain size of a planet...
    How is 4x4GB 1333 faster than 3x4GB 1600?
    But in any case you won't notice the difference, except in very memory speed sensitive apps or when using the IGP, but it's very minimal. My suggestion, go for the more memory.
  7. Krane
    Krane Notebook Prophet
    Definitely go with more vs faster. As far as noticeable difference--one step is meaningless; two steps is marginal.
  8. Khoiboi
    Khoiboi Notebook Guru
    Wouldn't the 4x4gb be faster due to the dual channel RAM? The 2nd set in the 3x4gb wouldn't benefit. Honest question, I've never really been that sure on the whole dual channel RAM thing.
  9. sarge_
    Ever heard of dual-channel memory? Of course it's gonna be faster.
  10. HTWingNut
    Ever heard of asynchronous dual channel? It will not be measurably faster. In any case you're splitting hairs in performance for 99.999% of users and applications.
  11. Rishwin
    No it doesn't, and yes i can.
    The 4x4GB dual-channel performance increase will completely nullify any performance gains by getting 1600MHZ instead (not to mention most laptops only support up to 1333MHz) and then there's that whole extra 4GB of RAM.
    And you're not? Ironic considering you're arguing a noticeable difference between 1333MHz & 1600MHz.
    Plus, asynchronous dual channel applies to different capacities, you still need the 4 sticks of RAM for it to work. 3x 1600MHz still isn't going to help you there.
    Keep in mind the OP is specifically asking about 3x4GB dimms, not 2x4GB & 2x2GB.
  12. tilleroftheearth
    In a new Ivy Bridge based notebook, I had the chance to try 2x4GB 1600MHz RAM vs. 2x8GB 1333MHz RAM and I noticed a huge and immediate performance drop when the (16GB) lower spec'd but higher capacity SoDimms were installed.
    The whole system felt sluggish; IE would take a few seconds to display new webpages and basically the i7 3610QM system responded like something from 2007.
    Putting the 1600MHz (8GB total) RAM back, the system felt once again like the 2012 high performance system it is (even with the ancient 5400RPM HDD the system shipped with).
    My advice: keep saving until you can afford the proper rated RAM for your system (I'm assuming this will be going into an Ivy Bridge system, of course). If we're talking about a Sandy Bridge based system, then I'll agree with most here that the 1333MHz SoDimms (16GB total) will be the superior configuration - unless it's installed in a very highend i7 (XM) SB based system).
    Good luck.
  13. Rishwin
    Why would you be assuming this is for an Ivy Bridge system? What has been said where which would give you that indication?
    Also you're comparing 8GB of 1600MHz with 16GB of 1333MHz, it's documented that systems can run slugish if too much memory is installed but unused and I've observed this myself. Not to mention not every chipset or board supports 8GB dimms.
  14. tilleroftheearth
    Where have you seen that 'too much memory makes systems run sluggish'? ROTHFLMAO
    By stating my assumptions, I don't have to care what system is being considered: (especially since none are mentioned by the OP at all) - and my observations stand on their own.
  15. HTWingNut
    No you don't. Asynchronous works with any number of sticks. Since there's only two memory controllers having 8GB (2x4GB) in one channel and 4GB (1x4GB) in the other will still be asynchronous. Asynchronous works with single + dual channel and optimizes for use with RAM amount that is dual channel. So in my example 8GB would be dual channel and the other 4GB single. In Intel systems it's called "Flex Memory". In any case it really doesn't matter much.
  16. Rishwin
    Some older controllers run slower when using 8GB dimms, most don't have native support for them. Also from memory the only 1st gen i-series chip which supports 8GB dimms is the i7. 8GB in dimms in general have some compatibility issues and can not simply be used in every system.
  17. Jarhead
    Jarhead Luigi #1
    My vote for OP: get whatever is on sale. Seriously. Assuming that your laptop has a dGPU (in iGPU case, 1600MHz might be better).
    Ignoring iGPU, you won't notice **any** difference between the two choices, other than a 4GB difference. Even then, you probably won't max out 12GB (I've tried everything other than some scientific computing and 4+ VMs, which will max that out). 1333MHz and 1600MHz won't matter to you unless you're benchmarking (basically: "I got bigger numbers than you!! So mine's better!!" in my book).
  18. HTWingNut
    8GB is MORE than adequate unless you run lots of VM's or have specialized software that needs tons of RAM. 1333 vs 1600 MHz is minor difference.
  19. tilleroftheearth
    I'll repeat again that on an Ivy Bridge based system 1333MHz SoDimms made a new system basically unusable.
    You've been warned...
  20. Jarhead
    Jarhead Luigi #1
Similar Threads: Memory 16GB
Forum Title Date
Hardware Components and Aftermarket Upgrades 16GB memory - Kingston or Cruicial? Nov 29, 2012
Hardware Components and Aftermarket Upgrades extend TOSHIBA SATELLITE L 20-112 - memory to 2 GB - doable? Jan 8, 2015
Hardware Components and Aftermarket Upgrades Memory recommendations Dec 12, 2014
Hardware Components and Aftermarket Upgrades ASUS U31F won't boot after Memory Upgrade Nov 18, 2014
Hardware Components and Aftermarket Upgrades Upgrade memory and LCD on Lenovo laptop without losing warranty? Nov 1, 2014
