maximum upgrade for m15x
Discussion in 'Alienware M15x' started by mejoh, Oct 15, 2017.
  1. mejoh
    mejoh Notebook Enthusiast
    ok ill try to figure out how to do tat...
  2. kosti
    kosti Notebook Virtuoso
    According to some here, the 240W SLIM adapter does not have throttling issues with the M15X and does not require pulling the center pin. Otherwise, a right angle adapter is a way around the issue but they are hard to find unless you are in the U.S. Alternatively you can make an adapter of your own if you have some soldering skills and the right parts.
  3. King of Interns
    King of Interns Simply a laptop enthusiast
    Or even better a dual PSU mod :)
  4. deadsmiley
    deadsmiley Notebook Deity
    I am afraid I was very WRONG on that.
    MZWiZard and kosti like this.
  5. kosti
    Oh well. The right angle adapter it is then :D.
    Like I said previously, you can even make one yourself for a couple of dollars. Just get a Dell 7.4mm female power jack and a Dell 7.4mm male power plug and wire them together without connecting the center pin wire. You can even take it a step further and install a switch to switch between the middle pin being connected or disconnected. I made one of these if anyone is interested.
  6. mejoh
    Wow u guys really figure this things out. Well, im not buying the gc yet so i'll try use my default adapter. Hopes my new proc isnt power hungry.
  7. nforce4max
    nforce4max Notebook Geek
    As is the cpu doesn't hog much until you start nuking an xm and only then does it pull a lot power wise, using a slim 240w and it is pretty good so far even though the battery I have may as well be a potato (dead).
    kosti likes this.
  8. mejoh
    can u guys give me ebay link for the 240w adapter...
  9. dean1keaton
    dean1keaton Notebook Enthusiast
  10. mejoh
    ok...i just found it on ebay au...its 60 bucks...tats good enough
