MAX Q
Discussion in '2015+ Alienware 13 / 15 / 17' started by wrathofdeath, May 31, 2017.
  1. wrathofdeath
    wrathofdeath Notebook Evangelist
    So, I don't understand... will the new q chips be faster than the current 60, 70 & 80 chips? I guess all that I'm reading about is performance per mm of chassis. IDK how this related to actual performance since the q chips will need less wattage to run at max performance it seems. And since they aren't a new design and still Pascal, I guess I just don't get the difference in GPU's, only that they will be able to shove a big mac into a water bottle.
    hmscott likes this.
  2. Mobius 1
    take a look at the razer blade pro gtx 1080 as a max-q
    it's a 1080, that performs slower than a gimped 1070 on an alienware 17 (115w)
    so you're buying a next tier product with a slim design premium, that performs worse than a previous tier product which has already been gimped
    ain't that right @Razer Customer Support @RazerCS
    huh, HUH?
  3. ThatOldGuy
    ThatOldGuy Notebook Virtuoso
    Max-Q is marketing jargon. They are the same 60, 70, 80 chips with a purposefully lowered TDP and lowered clock boost. They are then stuffed in thin ultrabooks and sold at a premium. Its all so they can say "this 15" laptop has a GTX 1080 in it" when it is barley on the level of a GTX 1070 (and it most likely will still throttle even more because ultrabooks cant cool even a 1070)
    Overall they are scamming customers with fancy graphs, charts, and "ultrathin" GTX 1070 and 1080 notebooks that perform like a GPU class below, but demand full Top end GPU price.
    Biggest problem here is that, while release statements say Max-Q on the press release, they do not in the spec sheets. Many customers won't know there is a difference.
  4. Mobius 1
    couldn't have said it better myself
    +rep
  5. shadowyani
    shadowyani Notebook Deity
    I'm holding my breath until I see the numbers. Evidenced-based approach or bust!
    That being said, physics has a nasty habit of being real.
    Onetwo345 likes this.
  6. Onetwo345
    Onetwo345 Notebook Geek
    It seems interesting, I personally would like to see laptop manufacturers do a thinner more portable range like the Max-Q designs I've seen so far, alongside a thicker full power range of laptops with full TDP. They should have to show the percentage performance difference between a regular GPU and the ultrabook version in all marketing, so people aren't surprised that one is hotter and weaker despite having the same hardware. Apparently Max-Q specs say the laptop fans must be under 40 dB under full load too, so I'm looking forward to seeing what cooling solutions these thin chassis will have.
  7. cskx2001
    cskx2001 Notebook Consultant
    So this is that refresh that was being talked about MONTHS ago of lower TDP versions of their cards, nice.
  8. don_svetlio
    The Max-Q GPUs are basically taking 2 steps back and bringing the "M" mobile GPUs.
    1080 Max-Q is a 1080M that performs slightly under a 1070
    1070 Max-Q is a 1070M that performs slightly above the 1060
    1060 Max-Q is a 1060M that performs around an OCed 1050 Ti
    At least how I understand it
    shinryu744 likes this.
  9. Mobius 1
    and max-q laptop cost more than the normal machines that outperform them
  10. Onetwo345
    I'd like to see some specs soon before stating that the GPUs will be worse than the class below. Also I doubt it'll be that bad, a full power 1060 can and will fit in a thin laptop without any real problems eg aero 15. So theres no reason to make it run like a 1050? If they can keep the majority of a chips performance while at a lower TDP this can only be a good thing. Also I doubt every single gaming laptop will adopt this design so people shouldn't worry, there will still be plenty of non Max-Q machines so if it's not your thing no problem. However many people (myself included) would trade some performance for a thin and light gaming laptop that can be carried all day. As long as it's not at an inexcusable price premium
