Manually setting connection speed to 1Gbit/s instead of 100Mb/s
Discussion in 'Linux Compatibility and Software' started by jimmyrazor, Oct 11, 2018.
  1. jimmyrazor
    jimmyrazor Newbie
    Ok so since i switched over from win10 i couldn't get 140Mbit/s internet connection as per contract and once i started messing arround i found this:
    sudo lshw -C Network
    [sudo] password for home:
    *-network
    description: Ethernet interface
    product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
    vendor: Realtek Semiconductor Co., Ltd.
    physical id: 0
    bus info: pci@0000:03:00.0
    logical name: enp3s0
    version: 0c
    serial: e0:d5:5e:3d:70:57
    capacity: 1Gbit/s
    width: 64 bits
    clock: 33MHz
    capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet
    physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
    configuration: autonegotiation=off broadcast=yes driver=r8169
    driverversion=2.3LK-NAPI duplex=full firmware=rtl8168g-2_0.0.1 02/06/13
    ip=192.168.100.17 latency=0 link=yes multicast=yes port=MII
    Nox Showbox Mobdro
    speed=100Mbit/s
    resources: irq:31 ioport:d000(size=256) memory:fe800000-fe800fff
    memory:d0000000-d0003fff
    and i tried to manually switch it to 1Gbit/s with
    sudo ethtool -s enp3s0 speed 1000 duplex full autoneg on
    and i just lose connection untill i run the command again with speed 100. I used the same cable and lan card on win10 and had the full 140Mbit/s connection, how come it is not working now.
    And also what is the difference between enp3s0 and eth0, almost every site i searched only mentions eth0 and very rarely enp3s0.
    Edit: this is the real lshw after the ethtool command ignore the one above
  2. ALLurGroceries
    ALLurGroceries   Super Moderator
    Dannemand and Dennismungai like this.
  3. Dennismungai
    Dennismungai Notebook Deity
    Could you try switching to the official realtek drivers? This blog entry documents the process. https://www.unixblogger.com/how-to-get-your-realtek-rtl8111rtl8168-working-updated-guide/
    Vasudev likes this.
