Manually keep backlight keyboard on Sony Vaio Z21
Discussion in 'VAIO / Sony' started by Butters149, Sep 16, 2011.
  1. Butters149
    Butters149 Notebook Consultant
    Hi,
    I just bought new sony vaio 21 and was wondering how can i keep the backlight keyboard on all the time? or manually switch it on and off?
    Thanks,
  2. anytimer
    anytimer Notebook Deity
    VAIO Control Center> Keyboard and mouse. :)
  3. MikeYbarra
    MikeYbarra Notebook Enthusiast
    No option exists to keep it on all the time. It has a auto-shut off at max length of 60 seconds (when KB not used). I too wish an option existed to keep it on in the dark all the time.
    Software seems fairly buggy (as always).
  4. Blahman
    Blahman Notebook Consultant
    Could you elaborate on this and explain how to do what he is asking? That is if it can be done.
  5. anytimer
    Why would you want to keep it on for more than 60 seconds? I have my display turn off after 2 minutes.
    Quick way to turn on the backlight without disturbing anything is to press the shift key. Pressing the caps lock key twice is also good.
    EDIT: are you thinking about putting the laptop in a display or something? Is that whay you want the keyboard backlit all the time?
  6. jeremyshaw
    jeremyshaw Big time Idiot
    Why not? I have my SC's KB light on at all times when it's plugged in...
    Then again, I'm a former Alienware owner, so maybe it's just a different camp of thought :p
    EDIT: though on the battery, it shuts off after 10sec, and only activates if it's dark.
  7. electronicsguy
    electronicsguy Notebook Evangelist
    It does have a 'do not turn off' option... you just need to update the vaio control center manually from a recent newwer laptop model like SA. Sony update sucks in its stupid micro-management of software across different product lines.
  8. anytimer
    Hey! That's a good trick. Do you know which model's Control Center I should try to use? I have a VPCZ1.
  9. Butters149
    How do u update to the SA version? Also I wish that this keyboard backlight was more even and brighter, like the macbooks
  10. lovelaptops
    lovelaptops MY FRIENDS CALL ME JEFF!
    I just read this thread and it made my head spin a bit.
    First, is it understood that the OP wants to be able to turn on the keyboard backlight at will, not only when the sensor thinks it's dark enough?
    Second, on the reccommendation that a "newer" Vaio Control Center be downloaded, such as the one for the SA, what could be newer than the Z21 the OP has? The SA has been out for months, and the Z21 for one month. Perhaps the SA has had a newer update?
    Third, I've had the same concern with my Z11 and I resoved it in a very low tech way: placed a tiny, carefully cut piece of black electrical tape over the sensor. I still have to press a key to get the light to go on, and it will turn off after no activity after whatever shut-off time is set, but it's really not very inconvenient. I find it easiest to just go for the Ctrl key in the lower left, using it like a keyboard light on switch.
    Hope this helps. It was just a little disconcerting to read a thread when it seemed like no one got the point of the OP's request.
