Macrium Reflect Installation/Usage Guide
Discussion in 'Windows OS and Software' started by Spartan@HIDevolution, May 11, 2017.
  1. Spartan@HIDevolution
    And how have you the expectation of him posting it when he hasn't a download link for the free version? The free version is not officially out unless someone leaks a download link on some forum :rolleyes:
    Papusan likes this.
  2. Papusan
    Yeah it seems his friend "Snappy Phoenix" have more than enough with searching info for a new taptop:D Or he had problems with his Gigatop and couldn't reach out to him at proper time:p
  3. Spartan@HIDevolution
    I had not the ability to find a link on my gigabyte taptop [​IMG] why don't you go to your German wonder site and use G00gl3 translate I know you can find everything there [​IMG]
    Papusan likes this.
  4. Papusan
    Use automatic translate. And yep, I like that German site. But as long its possible I want to support our friend Mr. Timmy at Majorgeeks. I even support him on YoooTube CIGAR.gif
  5. Papusan
    Macrium Reflect FREE Edition 8.0.6036 14th July 2021
    Mr. Timmy hadn't the change log. But here it is....
    Bug fixes and Improvements v8.0.6036 - 14th July 2021
    • Installer
      On pre-Windows 8 systems we've improved the detection of Windows SHA-2 patches to enable installation to continue.
    • Rescue Media Builder
      • When determining what size partition to create for USB rescue media, the Rescue Media Builder will now always allocate at least 20% more space than is required for the files to ensure enough space is allocated.
      • If the Rescue Media Builder could not find enough space on a USB stick to create the rescue media, the log could report incorrect partition numbers and size requirements. This has been resolved.
      • An invalid filename for an iso file could cause the iso file path to be malformed. This has been resolved.
    • Macrium Reflect UI - General
      • We've added a Full/Diff/Inc backup type column to the Log View list.
      • The 'Type' column in the 'Definition Files' view is now sortable.
      • Disabled menu items could sometimes appear as enabled when using the light theme. This has been resolved.
      • When trying to rename an XML definition file, the ‘c’ character could not be entered. This has been resolved.
      • The mouse pointer detection zone for check-boxes in the Browse Image dialog box was too small, making them difficult to interact with. This has been resolved.
      • Under Reflect Defaults, some text labels in the Email Settings could become misaligned. This has been resolved.
    • Existing Files View
      • We've changed the icon in the list of folders for network shares that can't connect and for folders that don't exist. We've also added a 'Connect' context menu to prompt for authentication and to display an appropriate error message for local folders.
      • Intermittent connection issues could cause the list of backups in a shared folder to be empty. This has been resolved.
      • Removing the last folder in the list of files to search in the existing backups view would not refresh the backups. This has been resolved.
    • Rescue Media
      • When authenticating a network share while booted into the Rescue Media, clicking the Show Password button could cause the Rescue Media to reboot. This has been resolved.
      • The backup run dialog could be clipped when running at 800x600 resolution. This has been resolved.
      • An incorrect VSS warning message box was displayed when imaging removable drives in the rescue media. This has been resolved.
      • We've increased the time-out when connecting to network shares to reduce connection failures.
      We recommend re-building your rescue media if these problems adversely affect you, or if you're unsure.
    • viBoot
      viBoot in VirtualBox mode now uses per-user repository for VMs instead of per-machine configuration. This is to bring it in-line with Oracle VM VirtualBox Manager UI. Existing VMs will be migrated to per-user repository when viBoot is restarted after installation.
    • Removable Drive Images
      Images of BitLocker encrypted flash/removable drives would fail with a file system error. This has been resolved.
    • Clone/Restore
      A drive letter could be incorrectly assigned when 'None' was selected for the target partition drive letter. This has been resolved. .
    • Server Plus Exchange
      • Exchange backups now show a more appropriate error when attempting to backup databases that changed location.
      • Encrypted and password protected Incremental backups could fail to append to an existing backup set. This has been resolved.
    • Various
      Various minor fixes and changes to improve Macrium Reflect.
  6. Papusan
    Patriot Supersonic Rage Prime USB 3.2 Gen2 1TB Flash Drive Review tweaktown.com
    Although a bit pricey for a 1TB USB drive, the Patriot Supersonic Rage Prime is legit! Join us as we run it through its paces.
    etern4l and Spartan@HIDevolution like this.
  7. Papusan
    Macrium Reflect FREE Edition 8.0.6161 7th Sept 2021
    Bug fixes and Improvements v8.0.6161 - 7th September 2021
    • General
      • We've added identification of external processes locking Macrium Reflect backup files when a sharing violation causes a failure in the backup or consolidation.
        Note: Process names can only be identified if they originate on the local PC and are traceable.
      • We've added a 'Reveal' button to show the typed/entered password when browsing/verifying/restoring password protected or encrypted images.
      • We've added a backup overall progress percentage tooltip to Reflect Monitor taskbar system tray icon
    • Localization
      • Recent backup folders were not always being copied when creating rescue media. This has been resolved.
      • We've added a network authentication prompt when saving an ISO file to a disconnected network share.
    • Technician's Rescue Media
      • The option to prefix the backup filename with IMAGEID was not available in PE/Portable mode. This has been resolved.
      • The toolbar for Defaults was not visible in Technician's PE/Portable mode. This has been resolved.
    • File and Folder Backup
      • Folders to backup were not added in alphabetic order. This has been resolved.
      • File & Folder backup wizard would not use the users locale date/time format for the folder date/time. This has been resolved.
    • Server Plus
      • The refresh of the Exchange backup cache could lead to a "Not Responding" state. This has been resolved.
      • Exchange backup could lead to an error "Not Enough Storage is available to process this command". This has been resolved.
      • A program exception could occur when specifying an alternate location for SQL Server database restore. This has been resolved.
    • Clone
      • Email Attachments were missing for Clone operation. This has been resolved.
      • Clone operations could fail to start if Forensic Copy was selected. This has been resolved.
    • Image
      An edge case with some flash drives could cause the last physical cluster of an imaged file system to be skipped. This has been resolved.
    • Changed Block Tracker
      • The CBT state in Macrium Reflect menus would not always track the current CBT state correctly. This has been resolved.
      • On some systems, CBT could not be enabled on the system volume. This has been resolved.
    • Image Mounting
      • Mounted NTFS volumes would show as tbFAT in the Windows Explorer properties dialog when the option to "Allow access to restricted folders" had been checked. This has been resolved.
      • When mounting an image the image comment would be displayed over the checkbox forcing 2 clicks to enable the checkbox. This has been resolved.
      • When an image is automatically dismounted as part of consolidation, the Unmount backup dialog would retain the mounted volume. This has been resolved.
    • Defaults and Settings
      • The network authentication defaults now has a Test option to test connectivity.
      • On 32 bit systems, default network user names were not being saved. This has been resolved.
    • Log View
      • The toolbar on the Log View could become corrupt when hiding the filters after switching tabs. This has been resolved.
      • The Log view refresh button was clearing the log filters. This has been resolved.
    • Existing Backups View
      • The Existing Backups View browse option would not automatically select the file that was browsed for. This has been resolved.
      • We've made the 'Folders list' column in the Existing Backups View re-sizable.
    • Reflect Monitor
      Cancelling a backup in Reflect Monitor could leave some buttons disabled. This has been resolved.
    • Various
    etern4l likes this.
  8. pathfindercod
    pathfindercod Notebook Virtuoso
    I miss Spartans iso releases of this so i could make a bootable usb. Anyone happen to have the latest version bootable with 11th gen support? The one i have will not see the nvme on a 11th gen system. :-(
  9. Papusan
    This is the latest version if I remember correctly Macrium Reflect FREE Edition 8.0.6161 (Bootable Rescue.iso)
    pathfindercod likes this.
  10. Spartan@HIDevolution
    Papusan likes this.
