MacBook Pro Won't start
Discussion in 'Apple and Mac OS X' started by Omela, Dec 25, 2010.
  1. Omela
    Omela Notebook Consultant
    Hi all
    Today my MBP (2008) died
    after standby screen monitor wont' turn on backlight - I was able to see that all was working but backlight. So I've pressed OFF button to switch MBP off.
    After that MBP wont even show "apple" logo on start up and starting melody also never played.
    I've tried to boot fron MAC OS startup disk - but in vain. pressing ''D" or "C" on keyboard also won't work. I can hear disk spin up but nothing works.
    How to boot this damn thing up? What can it be.
    And how to export VMFusion files I need to other PC ( I don't have any Mac near me)
  2. Nick
    Nick Professor Carnista
  3. Omela
    Isn't working
    ALT+CMD+P+R not working - I can't even see "gray screen" seems that screen even dont light up.
    Also I can't eject DVD with Mac OS - pressing touchpad button do nothing
  4. CUDA.
    CUDA. Guest
    Try taking the battery out and then replacing it, failing that plug the power cord into the mains and attach to macbook,l and then it should come on.
  5. Omela
    Battery died few month ago so I don't have it even.
  6. Seshan
    Seshan Rawrrr!
    Is it the unibody version?
  7. Omela
    No It's last pre Unibody version
  8. blackfridaywaslame
    blackfridaywaslame Notebook Guru
    Are you sure you don't hear the starting chime? Because if you can hear it, it might be this since you said it was from 2008
    MacBook Pro: Distorted video or no video issues
    That sounds an awful lot like what I had but I could still hear the start up chime even after the screen never turned on
    Easiest way is to find someone with a mac to run target disk mode... otherwise pay for a backup service... or SOL (unless someone else has another idea)
  9. Seshan
    Seshan Rawrrr!
    Graphics card probably died, it was a problem with that model. Call Apple.
  10. justinepeter754
    justinepeter754 Newbie
