Macbook Pro: Changing graphics card possible?
Discussion in 'Apple and Mac OS X' started by seeklink, Oct 31, 2007.
  1. seeklink
    seeklink Notebook Enthusiast
    Hi,
    Does anyone know if it's possible to buy the cheaper Macbook pro and then upgrade the graphics card to a higher one?
    I find the upgrades overpriced.
    I wanted to upgrade the memory and hard disk myself.
    If I am going to void the warranty by changing the hard disk, I can't void more warranty by changing the graphics card.
    What do you guys think?
  2. ivar
    ivar Notebook Deity
    Sorry, the answer will be no. :(
    It is possible with the wifi card, hard disk, memory and processor.
  3. coyoteunknown
    coyoteunknown Notebook Consultant
    Actually, isn't the processor also soldered to the motherboard just like the graphics processor?
  4. Sam
    Sam Notebook Virtuoso
    You won't be able to upgrade the graphics card on the MBP. Its soldered onto the motherboard.
  5. 00fez
    00fez Notebook Deity
    So is the processor, but anyone with an intermediate technical knowledge could do it. About the graphics card, I think technically it is possible, but you have to really know what you're doing. If I had cash to blow I would definitely love to upgrade the mbp with a better graphics card, processor, etc. The thing you have to factor in though, is the heat issue, depending on the graphics card you want to put in. I mean, the mbp gets hot enough as it is...I can't imagine how much hotter it would be with an 8700gt at factory clocks...
    Anything's possible I guess.
    Try at your own risk!!
  6. seeklink
    Actually I am thinking of only upgrading the memory of the graphics card. The lower model has only 128MB. I want the one with 256MB. I guess this is also soldered onto the chip and hence no.
  7. SaferSephiroth
    SaferSephiroth The calamity from within
    Just because it is soldered doesn't mean you can't, it depends on the differences between the chips. The biggest problem would be matching the traces with the pins and getting the GPU to recognize the new chip(s).
  8. seeklink
    I am prepared (and comfortable with) to take the notebook apart and change the hard disk.
    However, if there are no ready after market nVidia 8600GT 256MB card, and/or it involves removing the solders, I think it's not an option for me. I just can't do that.
    Apple is doing very well to squeeze money from us.
    Thank you guys for your input. I'll need to consider my options again.
  9. Xander
    Xander Paranoid Android
  10. fabarati
    fabarati Frorum Obfuscator
    You can't upgrade the memory chips on the GPU (You'll destroy it unless you REAALLY know what you're doing).
    The GPU is Soldered to the mother board, as is the CPU. There is nothing better to upgrade your graphics card to.
    Apple doesn't use MXM in Macbook pro.
    The CPU uses BGA layout, and the cpu can't be bought in retail stores (none that I've seen anyways).
    Upgrading the HDD your self on the MBP voids your warranty.
    It's cheaper to upgrade the memory yourself.
    Did I forget anything?
