Macbook Pro 16 Very Slow Performance with OLED TV 55
Discussion in 'Apple and Mac OS X' started by syngress, Dec 31, 2020.
  1. syngress
    syngress Notebook Enthusiast
    I try to experiment with external GPU (GTX1080TI on some EGPU Case) with MacbookPro16, maybe I can get 120Hz from my 55OLED Panel.
    I have AMD Radeon Pro 5500M on board, and if I read correctly on the net, I am limited by the OSX system to 60Hz on this external GPU ..
  2. saturnotaku
    There is no NVIDIA driver support for macOS - you would need an AMD GPU.
    etern4l and syngress like this.
  3. syngress
    For BigSur ? What about Catalina ?
  4. saturnotaku
    Nope. NVIDIA and Apple haven't been on speaking terms since around 2013.
    etern4l and Vasudev like this.
  5. syngress
    That's too bad, what can I get form AMD (cheapest GPU option) with 120Hz support ?
  6. Spartan@HIDevolution
    so this PWM means those vertical lines that appear on the screen when you film it with a camera but the human eye can't see? that's what's bad and what bothers you on the long run?
  7. Aivxtla
    Aivxtla Notebook Evangelist
    Kepler was the last officially supported nvidia GPU series.
    Some people got the Geforce 10XX series to work in Catalina via workarounds but not sure how well it performs or if it's worth the effort.
    Vasudev likes this.
  8. Aivxtla
    No it’s basically flashing the screen on/off as a means of brightness control. Lower the brightness, the lower the flashing rate. Higher the brightness higher the flashing rate.
    Some people are very sensitive to low PWM levels as one previous poster mentioned. Can have it on LCDs as well.
    Much better explanation here:
    https://www.notebookcheck.net/Why-Pulse-Width-Modulation-PWM-is-such-a-headache.270240.0.html
  9. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    No, those "lines" you see when sometimes recording a screen with a camera is from mismatch between panel refresh rate and camera capture frame rate. if they are out of sync, you will see those lines (like using a camera capturing at 30fps to a 60hz display)
    PWM is pulse width modulation, and is one way to control backlight by rapidly cycling it on/off. At high frequency, it is not a problem to me, as the human eye can only register so many Hz. However if the frequency is low, like example some OLED panels use 55-58Hz to modulate, the eye can detect that flicker of on/off and it can strain over time.
    saturnotaku, Vasudev and Aivxtla like this.
  10. saturnotaku
    I'd look for a used RX 570 or 580. If you're lucky, you may be able to find the former for under $100.
    Vasudev likes this.
