MacBook Pro 15 mid-2017 thermal throttling
Discussion in 'Apple and Mac OS X' started by ThePerfectStorm, Nov 28, 2017.
  1. ThePerfectStorm
    ThePerfectStorm Notebook Deity
    Have read a few posts here and there that say that the MBP 15 2017thermally throttles under load. How bad is the throttling (clock speeds and temperatures would be appreciated), and would it occur under heavy web browsing or light audio encoding?
    Also, is the Surface Book 2 15" better? I have heard that it throttles as well, though to what extent I'm not sure. Thanks.
    Sent from my SM-G935F using Tapatalk
  2. Sentential
    Sentential Notebook Consultant
    It's not that it thermally throttles (had a 2016) it's that it has a very low power limit and so when the GPU and CPU are both active it is likely to POWER throttle down the clock speed. Heat issues were more prevalent in the previous generation and not this one.
  3. Danishblunt
    Danishblunt Guest
    It does thermal throttle. 97C into 2ghzish.
    Arrrrbol likes this.
  4. don_svetlio
    It should settle around 2.4GHz with thermals around 90*C - it's not terrible but not good either. As for the Surface Book 2 - I have no real information on thermals for it.
  5. ThePerfectStorm
    Interesting information, thanks!
    Is 97C the sustained temperature? If so, how would that affect my use pattern?
    Would that cause lag and a poor user experience for my use case?
  6. Danishblunt
    Danishblunt Guest
    It will basicially break outside your warranty at some point. It's designed this way by apple to get as much money as possible from their customers. You can look on youtube after a guy named "luis rossman". He makes repair videos on Macbooks and explains how they are designed to die and what worthless garbage they are.
    Do yourself a favor and get yourself an Asus Zenbook. They look like Macbooks, have different color, last very very long on battery, are as slim and have actual processing power.
    https://www.asus.com/Laptops/ASUS-ZenBook-Pro-UX550VD/
    You'll be enjoying this far more.
    ThePerfectStorm likes this.
  7. don_svetlio
    This, more or less. The only thing I'd like to add is that it depends on which MacBook generation we are talking about. As Louis has said, the 2010-2011 models were horrible but the 2013-2014 models were solid so it all depends on how the innards are designed.
  8. ThePerfectStorm
    Thanks for the advice! Will definitely look at other options like the one you suggested.
  9. ThePerfectStorm
    Thanks for the info! Will definitely heed @Danishblunt and your warnings.
  10. Danishblunt
    Danishblunt Guest
    EDIT: at 1min, what you wanna hear.
    KCETech1 and ThePerfectStorm like this.
