M34/28 on XP,ME,2000,98, and 95 guide
Discussion in 'Panasonic' started by Wyoming88!, Jun 9, 2019.
  1. Dr. Trout
    Dr. Trout Notebook Enthusiast
    Here is the parts list for the 19
    Toughbook CF-19 Replacement Parts List
    The Toughbook CF-19 is available in two distinct versions. The touchscreen unit runs Genuine Windows 7® Profeccional (with XP downgrade option) and functions as a fully rugged compact PC, allowing the user to interface with applications via a stylus or a finger. The electromagnetic dual touch version leverages Windows 7® Tablet PC functions. The magnetic plate behind the screen interfaces with a stylus only and allows for functionality such as hand-writing recognition, draft design, and signature capture. Both versions boast a daylight-readable 10.4" LCD swivel display, which can rotate in virtually any direction, converting from vertical to horizontal format in order to retain optimal visibility and ease of use.
    CF-19FHGAXxM NRP: Non Reusable Parts
    PART NO. DESCRIPTION Q'TY
    E1 DL31U1633AAA PCB, MAIN RTL 1
    E2 DL32U1633AAA PCB, AUDIO RTL 1
    E3 DL33U1633AAA PCB, IO RTL 1
    E4 DL31U1634AAA PCB, PAD RTL 1
    E5 DL32U1634AAA PCB, SW RTL 1
    E6 DL33U1634AAA PCB, LED-LEFT RTL 1
    E7 DL34U1634AAA PCB, PR RTL 1
    E8 DL36U1634AAA PCB, LED-RIGHT RTL 1
    E9 DL37U1634AAA PCB, SD RTL 1
    E10 DL38U1634AAA PCB, HSDPA RTL 1
    E11 DL39U1634AAA PCB, POWERSW RTL 1
    E12 DL3UP1552AAA PCB, EXT ANT UNIT RTL 1
    E13 DL31U1635AAA PCB, BT RTL 1
    E14 DL3UP1566AAA BAT FPC UNIT 1
    E15 DL3U11553AAA WWAN MAIN ANT RTL 1
    E16 DL3U21553AAA WWAN AUX ANT RTL 1
    E17 DL3U31553AAA LAN-MAIN BT ANT RTL 1
    E18 DL3U41553AAA LAN AUX ANT RTL 1
    E19 DL3UP1605AAA CF-19 TS PCB UNIT RTL 1
    E20 DFJS1060ZA WWAN COAXIAL CABLE 1
    E21 DFJS1117ZA LCD CABLE TS 1
    E22 S N0GB1J000019 INVERTER 1
    E23 S N3CAYYY00030 HARD DISK 1
    E24 N2AZZY000078 KEYBOARD VISTA, U.S. 1
    E25 DFJS1120ZA MODEM CABLE 1
    E26 S N5HAZ0000014 MODEM 1
    E27 N5ZZ00000128 DDR2-667 200PIN SO-DIMM, 1GB 1
    E28 DFJS1059ZA WLAN COAXIAL CABLE 1
    E29 S N5HZC0000031 WIRELESS LAN MODULE 1
    E30 D4CZY103A003 THERMISTOR 1
    E31 DFJS1043ZA POWER SW CABLE 1
    E32 N2EABEC00006 TOUCHPAD 1
    E33 BR-2330A/SF LITHIUM COIN BATTERY 1
    E34 DFJS1119ZA LAN CABLE 1
    E35 K1NB94B00001 EXPRESS PCMCIA COMBO SLOT 1
    E36 DFWV08A0108 LCD UNIT ASS'Y 1
    E36-1 DL3DW0186AAA LCD ASS'Y 1
    E36-1-1 A2CA00000056 LCD BACKLIGHT, CCFGL 1
    E36-1-2 DFHM0290ZA REFLECTION ANGLE 1
    E36-1-3 DFHR3H12YA LCD REFLECT TAPE 1
    E36-2 DFHR3612ZA LCD PWB SPACER 1
    E36-3 DFHR3647YA SPACER SHEET 2
    E36-4 DFHR3D92YA LCD BACK DAMPER 1
    E36-5 DFHR3570YA LCD BACK CUSHION 1
    E36-6 DFHR3571YA LCD BACK CUSHION S 2
    E36-7 DXHM0042ZA SCREW 2
    E36-8 DFHR3648ZA HOLDER SHEET B 2
    E36-10 DFHR3B64ZA LCD SIDE CUSHION A 2
    E36-11 DFHR3506YA LCD SIDE CUSHION C 2
    E36-12 DFHR3507YA LCD SIDE CUSHION D 1
    E36-13 DFHR3G97ZA LCD BACK SPACER TS 2
    E36-14 DFHR3G99ZA LCD REAR CUSHION F 2
    E36-15 DFHR3H84ZA LCD REAR CUSHION I 1
    E36-16 DFMX0383TA INSULATION PARTS 1
    E401 DFUP1587ZA FPC, AUDIO 40PIN 1
    E402 DFUP1588ZA FPC, IO 24PIN 1
    Note : Important Safety Notice
    Components identified by mark have special characteristics important for safety.
    When replacing any of these components, use only manufacturer's specified parts.
    Main Block Unit
    REF. NO and OS
    74 / 90E403 DFUP1644ZA FPC, SD(19MK2 SD LAN 24PIN) 1
    E404 DFUP1586ZA FPC, HSDPA 50PIN 1
    E405 DFUP1645ZA FPC, BT(19MK2 BT FPC 10PIN) 1
    E406 DFUP1589ZA FPC, PAD 40PIN 1
    E407 DFUP1591ZA FPC, LED LEFT 10PIN 2
    E409 DFUP1593ZA FPC, LED RIGHT 6PIN 1
    A1 S NCR-B/603A LITHIUM ION BATTERY PACK 1
    A2 S CF-AA1633AM1 AC ADAPTOR 1
    A3 S K2CG3DR00003 AC CORD 1
    A4 (A) S DFQW5088ZA OPERATING INSTRUCTIONS(CF-19MK2) 1
    A4 (J) S DFQW5097ZA MANUAL(CF-19MK2 VISTA) 1
    A5 DFJS954ZA MODEM CABLE 1
    A6 DFHS9017ZA TOUCHPANEL CLOTH 1
    A7 (A) DFQM8379MA RECOVERY DVD, VISTA 1
    A8 DFQC9006ZB-0 SHOULDER BELT ASS'Y 1
    P1 DFPE0733YA HOLDER 1
    P2 DFPE0859YA HOLDER 1
    P3 DFPK1210WA PACKING CASE 1
    P4 DFPK1216YA ACCESSORY BOX 1
    K1 DFHM9017ZA-0 EZC LID ASS'Y 1
    K3 DFHR9125ZD-0 PALM REST ASS'Y 1
    K3-1 DFHR3578ZA PARMREST TAPE OUTSIDE NRP 1
    K3-2 DFHR3580YA PARMREST TAPE RUBBER NRP 1
    K5 DFQC9009ZC-0 STRAP BG ASS'Y 1
    K6 S DFKE9059YA LOCK PLATE ASS'Y 1
    K7 DFBH3029UA HINGE 1
    K8 DFME0148YA PEN TETHER 1
    K9 S DFKE9086ZA-0 HINGE TOP COVER ASM 1
    K10 S DFWV80A0401 LCD FRONT CABINET/TS PANEL ASS'Y 1
    K10-1 S DFKF9033VB-1 LCD FRONT CASE ASS'Y TS 1
    K10-1-1 DFJS1064ZA SPEAKER CABLE 1
    K10-1-2 L0AA04C00012 SPEAKER 1
    K10-1-3 DFHG1634YA-0 LCD CABINET CUSHION A NRP 2
    K10-1-4 DFHG1635ZA-0 LCD CABINET CUSHION B NRP 2
    K10-1-5 DFHM0319YA LCD ELEPASS 2
    K10-1-6 DFHM0321ZA D WASHER 2
    K10-1-7 DFHM0322ZA SPRING WASHER 2
    K10-1-8 DFHM0413ZA SPEAKER PLATE 1
    K10-1-9 DFHR3469ZA PEN FRICTION SHEET NRP 1
    K10-1-10 DFHR3H08ZA SPEAKER WP SHEET NRP 1
    K10-1-11 DFHR6282ZB PEN HOLDER 1
    K10-1-12 S DFKM0521VA-1 FRONT CASE TS BLACK 1
    K10-1-13 DRHM5025YAT SCREW 4
    K10-2 DFHE0805ZA MAGNET 1
    K10-3 DFHP7149ZA MAGNET TAPE NRP 1
    K10-4 DFWV84A0308 TOUCH SCREEN PANEL KIT 1
    K10-4-1 DL3DV0186AAA TS PANEL ASS'Y 1
    K10-4-1-1 DFHR9071ZA PROTECTIVE FILM 1
    K10-4-2 DFHR3630ZA TS FPC SPACER NRP 1
    K10-4-3 DFHR3476ZA TS SPACER A NRP 2
    K10-4-4 DFHR3477ZA TS SPACER B NRP 2
    K10-4-5 DFHR3464WA LCD SIDE CUSHION B TS NRP 2
    K11 DFWV80C0532 LCD REAR CABINET ASS'Y 1
    K11-1 S DFKM9039YA-0 REAR CASE ASS'Y 1
    K11-1-1 DFHG1634YA-0 LCD CABINET CUSHION A NRP 2
    K11-1-2 DFHG1635ZA-0 LCD CABNET CUSHION B NRP 2
    K11-1-3 DFHM0319YA LCD ELEPASS 2
    K11-1-4 DFHM0321ZA D WASHER 2
    K11-1-5 DFHM0322ZA SPRING WASHER 2
    K11-1-6 S DFKM0522YA-0 REAR CASE 1
    K11-2 DFHR3J19ZA LCD REAR CUSHION J NRP 2
    K11-3 DFHR3460YA LCD REAR CUSHION A NRP 2
    K11-4 DFHR3567YA LCD REAR CUSHION G NRP 2
    Packing Material
    Mechanical Parts
    Accessories
    75 / 90K11-6 DFHR3563YA LCD REAR CUSHION C NRP 1
    K11-7 DFHR3564YA LCD REAR CUSHION D NRP 1
    K11-8 DFHR3565YA LCD REAR CUSHION E NRP 2
    K11-9 DFGB0165YA-0 TOUGHBOOK BADGE NEW NRP 1
    K11-10 DFGB0131YA-0 PANASONIC BADGE 1
    K12 S DFKM9040WA-0 TOP CASE ASS'Y 1
    K12-1 DFHM0320YA TOP ELEPASS 2
    K12-2 DFHR3434ZA AUDIO WATERPROOF SHEET NRP 1
    K12-3 DFHR3440ZA DSUB WATERPROOF SHEET NRP 2
    K12-4 DFHR3470YA PSW WATERPROOF SHEET NRP 1
    K12-5 DFHR3D86ZA FS CASE WP SHEET NRP 1
    K12-6 DFHR3D94YA GPS HOLE SHEET A NRP 1
    K12-7 DFHR3E15ZA LAN WP SHEET NRP 1
    K12-8 DFHR3E16ZA MODEM WP SHEET NRP 1
    K12-9 DFHR3F00ZA 1394 WP SHEET NRP 1
    K12-10 DFHR3F01ZA USB BACK WP SHEET NRP 2
    K12-11 DFHR6276ZA-0 POWER SW KNOB 1
    K12-12 S DFKM0519WA-0 TOP CASE 1
    K12-13 S DFKE9089YA-0 BAT LID ASS'Y 1
    K12-13-1 DFBH3030ZA LID HINGE 2
    K12-13-2 DFHM0315YC LATCH PLATE BATTERY 1
    K12-13-3 DFHR3466YA LID KNOB SHEET NRP 1
    K12-13-4 DFHR3509YA BAT COVER SHEET NRP 1
    K12-13-5 S DFKE0889ZA-0 LID KNOB 1
    K12-13-6 S DFKE0891ZA-0 BAT LID 1
    K12-13-7 DFUN0068XA LID KNOB SPRING 1
    K12-13-8 DFUS0323ZA LID KNOB SPRING PLATE 1
    K12-13-9 DRHM0109ZAT SCREW 2
    K12-13-10 DRQT26+D3KLT SCREW 2
    K12-13-11 DXQT2+F3FNLT SCREW 1
    K12-14 S DFKE9090XA-0 HDD LID ASS'Y 1
    K12-14-1 DFBH3030ZA LID HINGE 2
    K12-14-2 DFHM0285XC LID LATCH PLATE 1
    K12-14-3 DFHR3466YA LID KNOB SHEET NRP 1
    K12-14-4 DFHR3508YA-0 HDD COVER SHEET NRP 1
    K12-14-5 S DFKE0889ZA-0 LID KNOB 1
    K12-14-6 S DFKE0890ZA-0 HDD LID 1
    K12-14-7 DFUN0068XA LID KNOB SPRING 1
    K12-14-8 DFUS0323ZA LID KNOB SPRING PLATE 1
    K12-14-9 DRHM0109ZAT SCREW 2
    K12-14-10 DRQT26+D3KLT SCREW 2
    K12-14-11 DRHM5025YAT SCREW 1
    K12-14-12 DFHR6218YA SPACER 2
    K12-15 S DFKE9091YA-0 PCMCIA LID ASS'Y 1
    K12-15-1 DFBH3030ZA LID HINGE 2
    K12-15-2 DFHM0285XC LID LATCH PLATE 1
    K12-15-3 DFHR3466YA LID KNOB SHEET NRP 1
    K12-15-4 DFHR3588RA-0 PCMCIA LID SHEET NRP 1
    K12-15-5 S DFKE0889ZA-0 LID KNOB 1
    K12-15-6 S DFKE0890ZA-0 HDD LID 1
    K12-15-7 DFUN0068XA LID KNOB SPRING 1
    K12-15-8 DFUS0323ZA LID KNOB SPRING PLATE 1
    K12-15-9 DRHM0109ZAT SCREW 2
    K12-15-10 DRHM5025YAT SCREW 1
    K12-15-11 DRQT26+D3KLT SCREW 2
    K12-15-12 DFHR6218YA SPACER 2
    K12-16 DRQT26+D3KLT SCREW 6
    K12-17 DXQT3+F4FNLT SCREW 2
    K13 S DFKE9092YA-0 TABLET LATCH ASS'Y 1
    K13-1 DFHG1669ZA TABLET LATCH SHEET NRP 1
    K13-2 DFHM0291ZA TABLET LATCH PLATE 1
    K13-3 DFHM0294WA TABLET LATCH PIN 2
    K13-4 DFHM0295ZA TABLET LATCH SHAFT 1
    K13-5 S DFKE0892ZA-0 TABLET LATCH KNOB 1
    K13-6 S DFKE0893YA-0 TABLET LATCH LEVER 1
    K13-7 DFNW1604ZA CUT WASHER 1
    76 / 90K13-8 DFUN0069XA LATCH KNOB SPRING 1
    K14 S DFKM9041XA-0 BOTTOM CASE ASS'Y 1
    K14-1 DFHM9016ZA-0 DIMM LID ASS'Y 1
    K14-1-1 DFHM0401ZA-0 DIMM LID 1
    K14-1-2 DFHR3E14ZA DIMM LID WP SHEET NRP 1
    K14-2 DFHM0410YA DU LID ANGLE 1
    K14-3 DFHR3441ZA DU LID WATERPROOF SHEET NRP 1
    K14-4 DFHR3F64ZA HDD BOTTOM SHEET 2
    K14-5 DFHR6283ZB-0 DU LID 1
    K14-6 S DFKM0518XA-0 BOTTOM CASE 1
    K14-7 DFUS0316ZA PLATE SPRING GUIDE PIN 2
    K14-8 DRHM5025YAT SCREW 6
    K14-9 DXQT2+D25FNL SCREW 7
    K15 DFHE1019YA DU CON SPONGE 1
    K16 DFHG1209ZA RUBBER HOOT 4
    K17 DFHG1996ZA-0 SERIAL LID RUBBER 1
    K18 DFHG1638ZB-0 MODEM LID RUBBER 1
    K19 DFHG1998ZA-0 USB LID RUBBER 1
    K20 DFHG1997ZA-0 RGB LID RUBBER 1
    K21 DFHG1660ZB-0 LAN LID RUBBER 1
    K22 DFHG1790ZA BAT CUSHION 1
    K23 DFHG1902ZA-0 DC-IN LID RUBBER 1
    K24 DFHG1903ZB-0 1394 LID RUBBER 1
    K25 DFHG1906ZA-0 AUDIO LID RUBBER 1
    K26 DFHG1907YB-0 USB LID RUBBER 2 1
    K27 DFHM0286YB LID RUBBER PLATE A 1
    K28 DFHM0288ZB LID RUBBER PLATE C 2
    K29 DFHM0296XA-0 LCD HINGE COVER(SILVER) 1
    K30 DFHM0302XA-1 KEYBOARD PLATE(L) 1
    K31 DFHM0303XA-0 KEYBOARD PLATE(R) 1
    K32 DFHM0311ZB LID RUBBER PLATE B 2
    K33 DFHM0403XA DU CNT ANGLE 1
    K34 DFHM0406ZA KBD CNT LID 1
    K35 DFHM0407ZA BAT CON ANGLE 1
    K37 DFHR3487YA PORTRE SHEET NRP 1
    K38 DFHR3636ZA CABLE HOLD SHEET NRP 1
    K39 DFHR3D91ZA KB CNT LID WP SHEET NRP 1
    K40 DFHR3E03ZA SD BLIND SHEET NRP 1
    K41 DFHR3E53ZA FS SCREW SHEET NRP 1
    K42 DFHR3F62ZA POWER SWITCH CABLE SHEET NRP 1
    K43 DFHR3G19ZA INSULATION SHEET NRP 2
    K45 DFHR6246ZA HDD GUIDE 1
    K46 DFHR6284ZA DIMM HOLDER 1
    K47 DFHR6286ZA-0 RF SW KNOB 1
    K48 DFHR6289YA BAT CON HOLDER 1
    K49 DFHR6290ZA-0 FS DUMMY CASE 1
    K50 DFHR6312ZA ANT CABLE HOLDER 1
    K51 DFHR7946ZA MP GUIDE SHEET NRP 1
    K52 DFHR9081ZA PEN 1
    K53 DFMC0870YA DU SPRING 1
    K54 DFMX0383TA INSULATION PARTS 9
    K55 DFMY0419ZA DIMM THERMAL RUBBER 1
    K57 DFHE0915ZA EMI SHEET 10X20 NRP 1
    K58 DFHM0325ZA CABLE HOLD PLATE 2
    K59 DFHR3432ZA ANT CABLE CUSHION NRP 4
    K61 DFHR3573YA LCD SIDE CUSHION E NRP 2
    K62 DFHR3574YA LCD SIDE CUSHION F NRP 1
    K63 DFHR3638XA DG TAPE 1
    K65 DFHR3G16ZA INSULATION SHEET 30X140 NRP 1
    K66 DFHR3G42ZA TAPE PEN HOLDER 2
    K67 DFHR6277ZA-0 CABLE HOLDER 2
    K68 DFHR6320ZA-0 ANT COVER 2
    K69 DFHR6279YA-0 TABLET LATCH COVER 1
    K70 DFHR6298ZA HINGE CABLE HOLDER 1
    K71 DFMC0685ZA LCD CONDUCTIVE TAPE NRP 1
    K72 DFMC0816ZA INV MIL SHEET 1
    77 / 90K73 DFMC0877YA INVERTER CASE 1
    K74 DFMC0878ZA INVERTER SHIELD SHEET NRP 1
    K76 DFMX1267ZA INVERTER CASE(BASE) 1
    K77 DFMX1268ZA INVERTER CASE(LOWER) 1
    K78 DFQT6077YA CAUTION LABEL 1
    K79 DFUQ0100ZA LOCK SPRING 2
    K80 DFWV99A0124 HDD MOUNTING KIT 1
    K80-1 DFHM0404ZB HDD CASE UPPER 1
    K80-2 DFHM0416YA HDD CASE LOWER 1
    K80-3 DFHR3589ZA HDD CASE TAB 1
    K80-4 DFHR3H58ZA HDD DAMPER 1
    K80-5 DFHR3F54ZA HDD CON SHEET 1
    K80-6 DFHR6297ZA HDD CONNECTOR GUARD 1
    K80-7 DL3UP1564CAA HDD FPC UNIT 1
    K80-8 DFMX0383TA INSULATION PARTS NRP 2
    K80-9 DFMX1265ZA INSULATION SHEET(HDD HEATER) NRP 1
    K80-10 DFMY3208ZA WLAN SHEET NRP 1
    K80-11 S L9DZYY000008 HEATER(HDD) 1
    K80-12 DXQT2+D4FNL SCREW 2
    K81 DFQT0045ZA ENERGY STAR LABEL 1
    K82 DFQT9A29ZA WINDOWS VISTA 1
    K83 DFQT9981ZA CENTRINO DUO LABEL 1
    K84 DFQT0055YA COA SERIAL LAMINATE NRP 1
    K85 S DFGT1094YA RATED LABEL 1
    K86 DFHD04H004YB HEXAGON SPACER H=4.2MM 2
    K87 DFHR3F85ZA MODEM CABLE SHEET NRP 1
    K88 DFMC0881ZA BUSTERAID MODEM NRP 2
    K90 DFHM0309YA-1 SIM LOCK PLATE 1
    K91 DFHR3G18ZA BIS HEAD SHEET NRP 1
    K92 DFHR3G24ZA BIS HEAD SHEET 2 NRP 1
    K93 DFMY3224ZA WLAN SHEET NRP 1
    K94 DFHM0412ZA RF-BT PLATE 1
    K95 DFHR3154ZA LCD CABLE TAPE NRP 1
    K96 DFHR5484ZA CLAMP 1
    K98 DFHE0326XA GASKET-65TSV10-4-15 1
    K99 DFHE0811YA GASKET-65TSV4-3-50 1
    K100 DFHE1031ZA GASKET-65TSV13-1.5-20 1
    K101 DFHG1962ZA POWER SPRING SHEET NRP 1
    K102 DFHP7200ZA AHDESIVE TAPE NRP 1
    K103 DFHP7256ZB RF LED PWB TAPE NRP 1
    K104 DFHP7257ZB LED PWB TAPE NRP 1
    K107 DFHR3438ZA CLICK BUTTON SHEET NRP 1
    K108 DFHR3483SA OPERATION SHEET 1
    K109 DFHR3J80ZA KB WP SHEET NRP 1
    K110 DFHR3642YA LCD CUSHION SHEET NRP 2
    K111 DFHR3643ZA TP BOTTOM TAPE NRP 1
    K112 DFHR3655YA HDD CASE SPACER 2
    K113 DFHR3D90ZA KB CNT HOLE CUSHION NRP 1
    K114 DFHR3D93ZB TP WP SHEET NRP 1
    K115 DFHR3D97ZA LED PWB TAPE NRP 1
    K116 DFHR3E02ZA PALM REST WP SHEET R NRP 1
    K117 DFHR3E19ZA LED SYAKOU SHEET NRP 1
    K118 DFHR3E34ZA RF SYAKOU SHEET NRP 1
    K120 DFHR3F55ZA OPERATION TAPE NRP 1
    K121 DFHR3F65ZA PC SHEET NRP 2
    K122 DFHR3F66ZB PET SHEET NRP 2
    K124 DFHR6044XA CLICK BUTTON PLATE 1
    K126 DFMD2182ZA PLATE HEAT PIPE 1
    K127 DFMD3125ZA BACK PLATE KENSINGTON 2 1
    K129 DFMY0278YA THERMAL SHEET NRP 1
    K130 DFMY0473ZA CPU HEAT PIPU RUBBER NRP 2
    K131 DFMY3208ZA WLAN SHEET NRP 1
    K132 DFMY5039ZA HEAT PIPE UNIT 1
    K133 DFUQ0111ZA POWER SW SPRING 1
    K137 DFMY3234ZA THERMAL DIFFUSION SHEET NRP 1
    K140 DFHR3488ZA ANTENNA SHEET NRP 1
    78 / 90K141 DFHG429YA IO DC TUBE 1
    K142 DFHR3G38ZA DIMM CUSHION 3
    K144 DFHP7270ZA ADHESIVE TAPE NRP 4
    K157 DFMX1339ZA BAT INSULATION SHEET NRP 1
    K158 DFHR3J82ZA LCD CABLE PROTECTER 1
    K159 DFHR6352ZA CABLE GUIDE HINGE 1
    K160 DFHR3F89ZA MCH SHEET NRP 1
    K161 DFHR3H64ZA COIN BAT SHEET NRP 1
    K162 DFHR6353ZA LAN CONN HOLDER 1
    K163 DFMC0901ZA GASKET-65TSV13-1(T9)-1.9 1
    K164 DFMY0472ZA THERMAL RUBBER CPU 1
    K165 DFMY0475ZA ICH RUBBER 2
    K166 DFHR3650ZA WATERPROOF SHEET NRP 1
    K167 DFHR3H95ZA LCD TS PWB SHEET NRP 1
    K1051 DFMY3264YA DIMM THERMAL SHEET NRP 1
    K1603 DFHR6339ZA-0 DUMMY EXPRESS CARD 1
    K1604 DFHR6340ZA-0 DUMMY PC CARD 1
    K1610 DFHR3J11ZA PCMCIA DUMMY CARD CUSHION 1
    N1 DFHE5025XA SCREW 33
    N2 DFHE5058ZB SCREW 4
    N3 DFHE5108ZA SCREW 4
    N4 DRHM0112ZA SCREW 2
    N5 DRHM0115ZA SCREW 2
    N6 DRHM5025YA SCREW 18
    N7 DRQT26+E5FKL SCREW 18
    N8 DRSB2+10FKL SCREW 2
    N9 DRSB2+5FKL SCREW 27
    N10 DRHM0061ZA SCREW 13
    N11 DRYN3+J6FKL SCREW 2
    N14 DRQT3+E4FKL SCREW 2
    N15 DXYN2+J6FNL SCREW 10
    N16 DXYN3+J10FNL SCREW 2
    N17 DXYN3+J8FNL SCREW 2
    N18 DXYN4+J8FNL SCREW 4
    N19 XSB2+3FNL SCREW 17
    Get (removed my moderator)
  2. Dr. Trout
    Hope that's useful to someone
    I checked on the Toshiba M34 , it's just a laptop
    Wyoming88! likes this.
  3. Michael AU
    Michael AU Notebook Geek
    Is that link spam?
  4. Wyoming88!
    Wyoming88! Notebook Evangelist
    For me it takes me to outlook on the App Store. But may vary
  5. toughasnails
    Not needed so was remover
  6. Springfield
    Springfield Notebook Deity
    So you do know how to turn off CAPS LOCK .... wasn't sure if you did, or were just virtually shouting at everyone
    Wyoming88!, toughasnails and UNCNDL1 like this.
