m18xr2 Gpu Running Hot, Thermal pads?
Discussion in 'Alienware 18 and M18x' started by Jango666, Dec 31, 2019.
  1. Jango666
    Jango666 Newbie
    My younger brother is running an M18xr2 with a gtx 770m that we purchased and installed. When gaming on demanding titles the temps run up to 95 degrees pretty quickly and I assume is throttled from there.
    Is there a guide to placing thermal pads on because I'm pretty sure they weren't put on properly when we got this replacement gpu.
    Mr. Fox likes this.
  2. Homer S
    Homer S Notebook Consultant
    I remember seeing one from @Mr. Fox IIRC. You would have to do some serious digging through the threads here.
    Homer
    Papusan and Mr. Fox like this.
  3. Mr. Fox
    Here you go. Had to do some digging in my Imgur archive. Uploaded 6 years ago to Imgur, LOL.
    If you want a better CPU fan, if you don't already have the more powerful 11.7 CFM fan (Dell P/N J77H4), get one. The other option is only 4 CFM.
  4. Maxware79
    Maxware79 Notebook Evangelist
    @Mr. Fox comes through again! I'm pretty sure my pads aren't right so this will help me out a lot. Thanks for keeping an eye on us Alienware tragics.
  5. Maxware79
    I got the pads right (as per the pic above) and my top temps in Fire Strike went from the mid 80's to now in the low to mid 70's. I also used a heatsink from another machine that looked brand new. I even pulled a better score in FS than previously.
    MagicMike, M18x-oldie and Mr. Fox like this.
  6. Homer S
    Sweet!
    I need to take a peek at my CPU fan...
    Homer
  7. Maxware79
    I’m still not running cool enough apparently. Some guy doesn’t get much past 60 degrees which sounds really low. What are your temps Homer?
  8. senso
    senso Notebook Deity
    Keep in mind that ambient temps play a significant role in system temp, one guy with 20ºC ambient temp will have a cooler running system than if you have 25ºC or 30ºC ambient temp..
  9. Maxware79
    That's a good point. The upstairs bedroom it's in does get warm even when the AC is on.
