M18x usb problems
Discussion in 'Alienware 18 and M18x' started by somthin4nothin, Sep 26, 2012.
  1. somthin4nothin
    somthin4nothin Notebook Guru
    Hi, I was wondering if this might be a driver issue or somthing but my external gets recognized in the 2 right usb ports. comes up and then like a minute later acts as if it got pulled out of the port and reboots up again. It works fine in the ports on the left side of the Laptop. Also, the cyan lighting scheme doesnt seem to be the same on the front as on the keyboard. anyone else have this problem
  2. UltraGSM
    UltraGSM ...so many Alienwares...
    dont know about unplugging itself, so far was all great, only one weird thing I discovered if I leave usb mice plugged in to one of my right usb3.0 ports laptop wont boot to OS, it will start booting and then will reboot to startup recovery as it failed to start, I just unplug the mouse and go restart again without it and it always works, so now getting used to never have my mice plugged in before starting up. Its some way BIOS related in my case I think. while leaving mouse in esata/usb combo port makes no harm
  3. Alienware-L_Porras
  4. alcaloide
    alcaloide Notebook Geek
    Link is not working, I mean, it goes to a nonexistent document.
  5. UltraGSM
    it doesnt really matter which brand, generic serial usb 2.0 cable mouse or wireless with usb nano adapter, etc rapoo 3200 mices and other behave same, its not always but most times, may call it often random.I kinda hate this but I must unplug my micro nano wireless mice receiver from usb port before I power up the laptop every time to avoid startup failure and startup recovery to kick in since it interferes with sata drives in some way. I have tried disabling legacy usb support in bios and it did not help either
  6. alcaloide
    May I suggest as a desperate measure a full windows installation AFTER clearing CMOS shorting it for about 15 seconds and pressing power with no batteries connected...
    Helped me in the not so long past. I was having so much trouble with usb ports and this procedure solved it.
    Good luck.
  7. UltraGSM
    looks absolutely weird suggestion, since I tried clearing cmos and etc nothing helped for me
  8. juliant
    juliant Notebook Deity
    I just got yesterday the Razer DeathStalker Ultimate installed and I am facing the same issues with the USB Ports (no matter which port). If the keyboard is plugged in the usb port while windows is booting (M18XR2), even if the keyboard is powered separately from an adapter the system goes in BSOD and restarts. At first I thought my problem of GPU driver has come back but realized that this happens only when the keyboard is plugged in.
    Otherwise this keyboard works amazing. Any suggestions are highly appreciated.
    Thank you.
  9. UltraGSM
    it looks like all the similar issues are since approx 3 months ago when i got my first M18X but I didnt pay much attention to that, now the second M18X has exact same , and more I read I see same happening for many others ... 3 BIOS upgrades there were since, A03, (A05 not publicized), A07 and last A08 none of these fixed any issues...
  10. Annie the Eagle
    Annie the Eagle Notebook Consultant
    I've noticed if something is in the USB 3 ports that has storage like an HDD, it will never finish loading the BIOS, with that red bar.
