M18x US Launch Info
Discussion in 'Alienware 18 and M18x' started by vzachari, Apr 27, 2011.
  1. koag8087
    koag8087 Notebook Guru
    so u guys r considering a pound same as a dollar
    right?
  2. joecait
    joecait Notebook Deity
    Agreed. 1999 was also mentioned in the launch presentation...
  3. NYC Drifter
    NYC Drifter Notebook Evangelist
    Debating cancellation of my recent order :confused:
  4. kraeuchii
    kraeuchii Notebook Enthusiast
    If it isn't up on the site when is the next expected date; I need a lappy nao! The only thing holding me back from the M14x is the seemingly impending release of the M18x.
  5. Robertd007
    Robertd007 Notebook Guru
    If it makes your decision easier, dell usually doesn't let you cancel your order after it goes into production. The only exception is if they delay it, which they have to give you the option to cancel.
    If it doesn't get delayed, they usually make you return it and pay up to 15% of the original purchase price + restocking fees I believe.
  6. JCrichton
    JCrichton Notebook Evangelist
    I'd be a little surprised at this point if it's not available for order early next week considering the prep that appears to be happening.
  7. RRei
    RRei Notebook Evangelist
    psh, i hope its available next week. time will tell.
  8. waffling_n00b
    waffling_n00b Newbie
    UK£ 490 = 818.79 U.S. dollars
    But then again, the base price definitely shows the overseas markup:
    UK£ 1 698.99 = 2 839.01 U.S. dollars
    Or would that be the Value Added Tax? I remember ten, twenty years ago Congress floated the idea of a VAT here in the US.
  9. sticky
    sticky Notebook Consultant
    My R3 is basically the same as yours. Depending on the final price, I will either keep it or return for the M18X.
  10. sticky
    If you order a new computer you won't have to pay the 15%. I had to argue with them all across India for hours about that.
