M18x turns on then shuts off right away
Discussion in 'Alienware 18 and M18x' started by ssj92, Dec 26, 2018.
  1. ssj92
    ssj92 Neutron Star
    So when I press the power button the laptop turns on and I see the boot screen for 1 second then it shuts off. At first it started doing this once then second time it would work fine but now it keeps doing it.
    I tried
    Removing battery
    AC only
    Power drain
    So far nothing hasn’t helped. Any ideas?
    Thanks
  2. Raja786
    Raja786 Notebook Consultant
    Try ram hot swap. That normally sorts 99% of issues for me.
  3. ssj92
    ssj92 Neutron Star
    Turn off UEFI and it booted. Back to UEFI and it’s working again for now. Feel like it’s gonna do what it was doing earlier again.
    @Rengsey R. H. Jr. @Raidriar yall ever experience this?
    Rengsey R. H. Jr. likes this.
  4. Rengsey R. H. Jr.
    Sometime I do experienced the shutdown after a tear down when I remove/add ram. Reseating it worked.
  5. ssj92
    ssj92 Neutron Star
    Feel like it could be a SSD. Sometimes the laptop gets frozen at the boot screen and I have to hard reset and it'll work next time.
  6. marcomarc
    marcomarc Notebook Enthusiast
    I would first open the base cover and chek if the ribbons are well connected.
    Then i would try without the battery if same outcome
  7. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    I do not have this problem, only after a bad overclock setting where the watchdog then resets certain settings, otherwise never.
  8. ssj92
    ssj92 Neutron Star
    It did it again, starts up shuts off. Did it 10 times then I decided to press F2 and enter the bios, and exit the bios now it booted.
    Do you think its a CPU overclock? I on;y have 4.2Ghz @ 5 flex right now and I've been running this for a long time.
    Or I wonder if it's s*** windows 10 but then it doesn't explain the shutting down part.
    I'll try turning off OC and reseat ram and see if it helps.
  9. imest
    imest Notebook Consultant
    I had this same issue in the past, I replaced my battery (ebay) and it has stopped happening... not sure if this was the fix as I did a tear down and rebuild before I swapped the battery.
  10. ssj92
    ssj92 Neutron Star
    Tried my newer battery (maybe few months old?) same issue.
    I pressed F12 at start-up , chose windows boot manager and it showed boot screen and shut off.
    Laptop never shuts off in BIOS so I am assuming this is a stupid Windows 10 thing. Think I'll reinstall 7 on this..
