[m18x] Troubleshooting liquid splash consequences
Discussion in 'Alienware 18 and M18x' started by @tomX, Feb 3, 2015.
  1. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Any of those keys are interrupt/override keys, thats the only reason why they would "stop" momentarily the volume up/down thing. Still would be worth cleaning the components, I don't know why you won't just go ahead and do it. Really, its not that hard and it would give us more information if it still doesn't work.
  2. UltraGSM
    UltraGSM ...so many Alienwares...
    disconnect that damn spilt keyboard, replace it with another one as I believe problem will go away. try w/o keyboard and report
    reborn2003 likes this.
  3. reborn2003
    reborn2003 THE CHIEF!
    I've experienced something similar like this. For my fix I bought a new keyboard and replaced it.
    Good luck with getting it fixed.
    Cheers. :)
    UltraGSM likes this.
  4. @tomX
    @tomX Notebook Evangelist
    Will try disconnecting keyboard to see if it changes something.
    Then I will try cleaning the socket... simple question : hace you seen the size of a Q-tip and the size of the socket slot? well its not really compatible...
  5. Mr. Fox
    You don't want to get any cotton fuzz stuck in there either. Use 91% alcohol as suggested with a soft bristled brush or a folded reinforced microfiber tissue (like the disposable eyeglass wipes), just be gentle not to disturb/distort the pins, then blow it dry with compressed air.
    reborn2003 and @tomX like this.
  6. @tomX
    Will try this WE, thanks for suggestions.
