m18x - removing wifi antenna cables
Discussion in 'Alienware 18 and M18x' started by anarky321, Jul 5, 2021.
  1. anarky321
    anarky321 Notebook Deity
    if anyone was ever annoyed like me about how much longer the disassembly/asssembly takes because of the antenna cables you have to thread through the hole in the motherboard - i finally went ahead and removed mine and its very fast - only 4 screws to get the monitor cover off and 4 more screws to get the 2 antennas off, and its reversible if you ever change your mind
    a micro-usb sized wifi adapter works just fine
    makes assembly much faster
  2. M18x-oldie
    What did you do, cut these cables?
  3. Maxware79
    Maxware79 Notebook Deity
    Sounds like he completely pulled the antenna cables from the LCD assembly.
  4. M18x-oldie
    That sounds like disassembling the screen lid, ok.
