m18x r2 works perfectly with gtx 1060
Discussion in 'Alienware 18 and M18x' started by tanzmeister, Apr 25, 2017.
  1. tanzmeister
    tanzmeister Notebook Evangelist
    not sure if it has been done already or not. but today I have tested MSI gtx 1060 6gb GPU to work perfectly in m18x r2 with unlocked bios and switchable graphics(optimus) enabled.
    @tomX, ssj92, Mr. Fox and 8 others like this.
  2. Glzmo
    Glzmo Notebook Deity
    Great. Thank you for sharing. Would you be so kind and share step by step instructions on how to do it and what's needed?
  3. tanzmeister
    you need unlocked bios, then switch to SG mode in advanced video settings, save changes without exit and just shut down the machine after that.
    tear the machine down, install the card( you will need to modify heatsink to fit the card, similar to 780m heatsink mod to fit 980m in AW18).
    when modding drivers nvdmi.inf 680m id replacement did not work for me! maybe just coincidence! so I have re-modded with nvmii.inf by replacing the right part of the string from 680m with the string from device manager.
    Aroc and maxslo like this.
  4. Glzmo
    Nice. Does the heatsink mod require any drilling or just cutting the plastic cover?
    Does this work with Windows 10 64 bit Creator's Update and the latest drivers as well?
    And would this BIOS from @Raidriar work for this purpose?
  5. Rengsey R. H. Jr.
    Dizzzzam , M18x still kicking and screaming !!!!
    Please do give us the full write up.
  6. jerryzago
    jerryzago Notebook Consultant
    The old beauty still rocks..... Please make a detailed process report and quirks you found along the way!
  7. tanzmeister
    you need to ground some of the metal that prevent the contact, sorry no pic atm.
  8. tanzmeister
    I can't ATM, I am switching homes. did the try up on the request, already spent too much of time I don't have right now.
    Aroc likes this.
  9. SMOKE_SKULL
    SMOKE_SKULL Notebook Deity
    What about the 1080s?
  10. Tulius
    Tulius Notebook Consultant
    And about performance? Is a 1060 GTX card most powerfull than a GTX 980M? Please add some 3Dmark scores if possible. Isn't need to flash bios card before installing on M18X-R2?
