M18x R2 with Quadro P5000 ( GTX 1070 ) is a success
Discussion in 'Alienware 18 and M18x' started by maxslo, Jan 22, 2018.
  1. maxslo
    maxslo undefined
    No, it only works with optimus on 60Hz screen. The M18x R1/R2 never had 120Hz screens.
    No hardmodding needed, all i did was flash Swicks/Raidriar's modded BIOS and changed Video from PEG to SG :)
    Modded the drivers and the install went just fine.
    Ashtrix and sicily428 like this.
  2. MahmoudDewy
    MahmoudDewy Gaming Laptops Master Race!
    :( I thought the 18 inchers didn't have optimus because they have SLI.
  3. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    M18x can SLI or do optimus with one GPU only
    maxslo and MahmoudDewy like this.
  4. MahmoudDewy
    This is a fact that was unknown to me till @maxslo post.
    maxslo likes this.
  5. ssj92
    ssj92 Neutron Star
    Can the AW18 also do optimus with the unlocked bios?
  6. skindoe
    skindoe Notebook Geek
    Yes, but the option in the Bios is only available if you use the unlocked AW18 bios.
  7. Rymesis
    Rymesis Notebook Consultant
    How did you end up modding the drivers?
    I've looked up a few guides, learned as much as I could and end up with a code 43.
    Just not sure if it's me being thick or if something else is going on.
    Edit: This is for a 1070
  8. liosafe
    liosafe Notebook Enthusiast
    I have also Alienware 18 haswell and also have unlock bios
    have nvidia quadro k5000m that suport lvds but this card don't work with this laptop
    when you switch to SG mode it's working until 1-st reboot after blue screen like you have
    and only one way to reset this is disassemble laptop take out card and it will work again until first reboot
    so this laptop is ...
  9. Rymesis
    That’s odd, one thing I had to do was replace my CMOS battery, for some reason when it lost power, even though it’s NVRAM, it would completely forget that I changed it to SG mode and I would have to go back in and change to SG mode
  10. liosafe
    yes some how in my case reset CMOS it's not enough I have to reset everything ram as well
