M18x R2 with Quadro P5000 ( GTX 1070 ) is a success
Discussion in 'Alienware 18 and M18x' started by maxslo, Jan 22, 2018.
  1. maxslo
    maxslo undefined
    Finally had the time to install the card yesterday.
    So far so good, the card never exceeded 75°C in tests, but it only has mx-4 applied at the moment, as i need longer holding screws due to the shorter xbracket.
    The heatsink fits like a glove and the card runs amazing :D
    https://www.3dmark.com/3dm11/12620788
    Edit: i did notice throttling (power related) according to the GPU-Z, but the card only throttles to 1500MHz, and not all the way down to base clock which is great :)
    Sent from my LG-H850 using Tapatalk
    jaybee83, triturbo, Ashtrix and 5 others like this.
  2. Danishblunt
    Danishblunt Guest
    pretty cool, it's performancewise between a 1060 and a 1070.
  3. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Debating going this route, where did you source the card?
    long2905 likes this.
  4. sicily428
    sicily428 Donuts!! :)
    could you test this card with specviewperf?
  5. maxslo
    maxslo undefined
    from a forum member :)
  6. maxslo
    maxslo undefined
    sure can, havent tried that before, how do i benchmark it?
    sicily428 likes this.
  7. sicily428
    maxslo likes this.
  8. ssj92
    ssj92 Neutron Star
    So you are the one that bought it, hehe looking good. M18xR2 continues to live on.
    Hoping to see 1170 and Quadro V5000M working as well. :D
    maxslo and sicily428 like this.
  9. MahmoudDewy
    MahmoudDewy Gaming Laptops Master Race!
    First, congratulations on the upgrade :) , So I understand that the card works well on the system without edp, optimus or 120Hz screen. So it is working on LVDS 60Hz screen without optimus right?
  10. CaerCadarn
    CaerCadarn Notebook Deity
    Based on that comment: was it basically plug&play? Or did you have to hard mod something?
    Sorry, I can't get the pics to open via Tapatalk.
    Gesendet von meinem ONEPLUS A5010 mit Tapatalk
