M18X R2 and GTX 1080
Discussion in 'Alienware 18 and M18x' started by Rengsey R. H. Jr., Dec 27, 2018.
  1. Maxware79
    Maxware79 Notebook Evangelist
    Would this mean that it would be possible to use the unused MXM slot for an NVMe drive?
  2. TheReciever
    TheReciever D! For Dragon!
    Dont think so, cant run 2 GPU's in SG mode, so by the reasoning I dont think other devices would function either.
    Of course I cant say for certain. I lack that knowledge.
  3. Maxware79
    Ahh that makes sense, unfortunately. Was hoping the machine would realize it wasn't a GPU and let it work.
  4. MagicMike
    MagicMike Notebook Consultant
  5. MagicMike
    When you say you cant run 2x devices in SG do you mean no power will be delivered to the secondary mxm port or that two actually running 2x cards in SG is not possible, I.e. they wont both work at the same time in SLI?
  6. senso
    senso Notebook Deity
    It should work. Not being able to use 2 GPU's is kinda expected if they are not running in SLI, most likelly due to OS limitation, the slot should still be powered up and the PCIe connection should still be working, given that its the card connected into the slot that signals the system to enable PCIe communications.
    Maxware79 likes this.
  7. MagicMike
    That's really what I am hoping would happen.
    So in MSI laptops then, where is the aux power for the 1080 coming from and what voltage / power is it?
  8. ssj92
    ssj92 Neutron Star
    In SG mode, both slots actually work. Even BIOS will see two GPUs. I think the issue was with windows BSOD.
    So NVMe in Slot 2 should work.
    M18x-oldie and MagicMike like this.
  9. TheReciever
    So maybe Linux might prevail where Windows fails? Color me surprised.
    M18x-oldie likes this.
  10. ssj92
    ssj92 Neutron Star
    Yes, Linux might be able to handle the situation.
    Think about it, people have ran iGPU + 2x SLI GPUs on mainstream desktop platforms fine.
    I think it's just a matter of how things are wired internally on the M18x.
