M18x R1 Upgrade > M18x R2 Motherboard
Discussion in 'Alienware 18 and M18x' started by Aikimox, Oct 4, 2012.
  1. mfractal
    mfractal T|I
    That sux.. Oh well, hope you get it eventually!
  2. Mr. Fox
    Update: Several of us have upgraded our M18x R1 with an M18x R2 mainboard. I could not be happier. If fact, I ordered a new OEM 3920XM CPU to make the transformation complete. (Although, the Sandy Bridge CPUs are working flawlessly in the Ivy Bridge board.)
    If you plan to do it, you will need to obtain the following components to upgrade your M18x R1:
    • 9D7N3 - M18x R2 Motherboard (GRP9C, G6CJP, FRVMD are also valid parts numbers)
    • YYFHR - M18x R2 I/O Daughterboard with ribbon cable
    • XVNKP - M18x R2 3-Disk HDD Caddy
    • M9T51 - M18x R2 SATA Interposer
  3. LannBot
    LannBot Notebook Consultant
    Good stuff guys, I'm glad this mod is working so well. It really shows the versatility of the AW brand when it comes to future upgrades.
  4. juliant
    juliant Notebook Deity
    Mr. Fox's next purchase a 'medium size' mSATA drive to use it as boot :)
  5. Lucifer Nymphetamine
    Lucifer Nymphetamine Notebook Consultant
    Good afternoon I am new here, I have an Alienware m18x R1, managed to put the mother board M18Xr2? is compatible? what you changed? which the the current configuration thanks awaiting my email: alonesoul_4 at hotmail dot com
  6. Mr. Fox
    Hello. See post #22 for necessary parts.
    Your Sandy Bridge (R1) CPU will work in the Ivy Bridge (R2) board.
    Lucifer Nymphetamine likes this.
  7. Lucifer Nymphetamine
    Did you know ''where'' i can found those parts? i like on Brazil i search on ebay and nothing , and i have another question maybe you know how fix, i change bios for a unlocked version, ok util then all fine , but after a time i change options on BIOS i dont remember ''all'' changes i do so laptop wont start not even BIOS.
    He restart, black screen (without any beep) wont load bios wont do nothing i tryed :
    I removed the battery from the motherboard, removed the notebook battery and power cord, trying it cause the motherboard back to original settings.
    Do not have any idea worked and / or know what the problem is?
  8. Lucifer Nymphetamine
  9. Lucifer Nymphetamine
  10. TBoneSan
    TBoneSan Laptop Fiend
    If you have a black screen from simply changing a BIOS setting you need to reset your CMOS chip.
    See Mr Fox's Post #5 here
