M18x overclocking and coolers :D
Discussion in 'Alienware 18 and M18x' started by evian_26, Apr 23, 2011.
  1. Lp18
    Lp18 Notebook Consultant
  2. GreaseMonkey90
    GreaseMonkey90 Notebook Evangelist
    it may not fit the size perfectly but less half an inch on both sides are no big problems. what counts is the fan position fits the m18x belly vents. it aligns exactly where it needs to be. same goes for the m17x r2.
  3. sungho2o8
    sungho2o8 Notebook Enthusiast
    coolermasters U3 works well, its larger than most.
    Allows you to put three fans wherever you want them, only downside is that it doesnt push much air, but its quiet.
    Its what I use on the m17x r3.
  4. Scanner
    Scanner Notebook Deity
    For an 18" laptop either one of these coolers will do. I use the Coolmaster Storm for my 18" lappy. I also had the NZXT Cryo LX, but I accidently broke it. The Cool-master storm pushes a lot more air then the NZXT Cryo LX, and is loud at full blast. But, once I get into the game, with the speakers blasting I don't hear the cooler, or anything else -I AM JUST SUCKED INTO THE GAME (I hope thats not a bad thing).
    Amazon.com: Cooler Master Storm SF 19 17" Laptop Cooler with USB 3.0 (SGA-6000-KKYF1): Electronics
    Amazon.com: NZXT ACC-NT-CRYO LX Aluminum Notebook Cooler 120MM Adjustable Fans (Black): Electronics
  5. AirJordan
    AirJordan Notebook Evangelist
    Scanner, have you ever tried using the Cooler Master on your lap? I previously had the Cryo LX but returned it and am now looking at the Cooler Master as another option. It looks like it would be much more comfortable to use on my lap since it has more of a base and is apparently a good amount lighter due to being made of plastic. I'm thinking of re-buying the Cryo LX and getting the Cooler Master at the same time to compare, but some first-hand advice would be nice. :)
  6. cookinwitdiesel
    cookinwitdiesel Retired Bencher
    Did not know anyone still sold the Cryo, good find!
  7. Scanner
    No, the cooler plus the lappy to big, not comfortable. I keep everything on my desk.
  8. miahsoul
    miahsoul Notebook Deity
    Screw coolers, go buy some dry ice! :p
