M18x Hard Drive caddy
Discussion in 'Alienware 18 and M18x' started by JTOverath, Apr 20, 2011.
  1. JTOverath
    JTOverath Notebook Evangelist
    Anybody else a little concerned over how the m18x supports 2 drives? Seems like stacking the drives on top of each other could cause issues with heat.
  2. iPhantomhives
    iPhantomhives Click the image to change your avatar.
    Maybe we could just use SSD ? SSD seem less heat consume.
  3. HSN21
    HSN21 Notebook Deity
    They should be fine, M17X r3 HD is stuck near the CPU/GPU yet it run just fine
    M18X drives is away from GPU/CPU from the screenshots i saw, Dell wont sell a laptop with HD issues, it would cost them a lot of money in the long run.
  4. eYe-I-aïe...
    eYe-I-aïe... Notebook Evangelist
    While HDDs (and SSDs) do indeed generate heat, it's far less than what the GPUs & CPU show.
    I would not worry at all about that.
  5. Mandrake
    Mandrake Notebook Nobel Laureate NBR Reviewer
    XPS 17 had stacked hdd and gpu.
  6. JTOverath
    OK cool.
    I may wait to decide if I am going to get one after one of the notebook masters on here gets one and lets the rest of us know if there are any issues ;)
  7. FXi
    FXi Notebook Deity
    I'm ordering when they are orderable and will do 1 SSD 1 physical drive and let you know. I don't know if I'll be the first however. There are a lot of hungry folks around here!
  8. JTOverath
    I will be eagerly awaiting reviews from folks on here when it does come out!
  9. cookinwitdiesel
    cookinwitdiesel Retired Bencher
    This describes me as well :D
    The X7200 and many clevo laptops have used this format for hard drives for a while now, I see no reason to be worried.
  10. FXi
    FXi Notebook Deity
    I think it will be fine. When you think about it, honestly the main drive you will be hitting is the SSD, so quite likely the physical drive isn't going to get warm all that often as it will be shut down much of the time.
    Don't think it's anything to be worried about.
