M18X can’t power on
Discussion in 'Alienware 18 and M18x' started by Volkly, Jan 11, 2019.
  1. Volkly
    Volkly Notebook Enthusiast
    Hi all, my m18x doesn’t turn on, I press the power button and you can hear that it’s trying to boot up and then a sound then it shuts down right away.
    Anyone have any idea what I should check first, cpu or mobo? Or is it time to say good bye :(
  2. Danishblunt
    Danishblunt Guest
    Well it would help if you tell us the beep code
    Volkly likes this.
  3. Rengsey R. H. Jr.
    And the beep code is “ How many beeps does the laptop make “.
    Volkly likes this.
  4. ssj92
    ssj92 Neutron Star
    And the "how many beeps does the laptop make" is per cycle.
    Example:
    8 beeps:
    BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP *1-2 second silence* BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP
    Hope that helps
    Volkly likes this.
  5. Volkly
    there are no beeps, it doesn't post, it seem to want to draw power and shuts down right away, as soon as i press the power button, you hear a small whine like something is powering on and then in a second or less, its shut down.
    Recap: press power button, fans turn on for half to 1 second and it shuts down.
    Rengsey R. H. Jr. likes this.
  6. Rengsey R. H. Jr.
    Remove all the rams and just use one stick.
    Volkly likes this.
  7. Danishblunt
    Danishblunt Guest
    Could you tell us what GPU you have?
    Volkly likes this.
  8. liosafe
    liosafe Notebook Enthusiast
    disassemble laptop and check Mosfet 4 that locate at the GPU 1 on left corner. if They are ok
    check this 2 Places use magnified glass. to see if there is any damage
    Part number for MOSFET:
    Good Luck.
    Volkly likes this.
  9. marcomarc
    marcomarc Notebook Enthusiast
    easy to change... i do that with AMTECH flux
    Volkly likes this.
  10. Volkly
    Thank you everyone!
    I have the GTX580x in SLI
    I will tear down the M18X and do as everyone suggested.
