M18x Battery Life
Discussion in 'Alienware 18 and M18x' started by ssj92, Jun 11, 2018.
  1. ssj92
    ssj92 Neutron Star
    For those of y'all that still have these beasts, can you tell me what battery life you are getting? Also settings, OS, usage type that gives you that battery life?
    I have two batteries, my original (4.9% wear) and a new one (0% wear apparently). Both of these batteries net me 3 hours of battery life. (Around 3 hrs 10 min total)
    this is with only iGPU enabled, 70-80% brightness, AlienFX on, Windows 10 latest version (better battery setting), web browsing usage. No timeout on display.
    I'm thinking of going back to 7 or 8.1. I feel like I should be getting 4+ hours but I'd like to see if that's what these laptops get.
    @Raidriar @Rengsey R. H. Jr.
  2. TheReciever
    TheReciever D! For Dragon!
    IIRC @bennyg had set up specific OS installations to get the most out of his battery life.
  3. bennyg
    bennyg Notebook Virtuoso
    nope not me
    Throttlestop and Windows power management profiles is all I bother doing. Not much point worrying about battery life on 17" SLI laptops without iGPU
  4. TheReciever
    Hmm then I can't remember who that was then but that's the method that particular member used to get more battery life.
  5. jerryzago
    jerryzago Notebook Consultant
    Mine is beat up, hardly can get one and a half hour on iGPU. I am on windows 10 also. I have them since the initial free distribution, but as far as I can remember, I could easily view two 2hour movies on a single charge.
    By the way, where did you source a new one? Since mine is beat up, I consider changing to fresh cells and upping them from 2100mah to 2900mah. I will possibly get a better battery or a bomb!
  6. ColaMonster
    ColaMonster Notebook Consultant
    My battery is so worn, Im lucky to get like 10 minutes of life out of it. LOL.
  7. ssj92
    ssj92 Neutron Star
    Think it was @Mr. Fox that used to get 4-6 hours on his. This is like my 4th M18x laptop and also remember getting 4+ hours before on my previous ones.
    https://www.ebay.com/itm/Genuine-96...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
    There's plenty of new batteries on eBay for the 18.
  8. Mr. Fox
    That is correct. That was with the M18xR2. I never got that much from the Alienware 18.
    ssj92 likes this.
  9. ssj92
    ssj92 Neutron Star
    Yeah my AW18 also only got around 2-3 hours max. But my older M18xR2's got at least 4+ hours. I'm trying to figure out if it's windows 10 or something else.
    I've already turned off start-up items, services, moved the battery slider to better battery in windows 10 and I can only get about 3 hours.
    Do you remember if Windows 8.1 and/or 10 reduced your battery life?
  10. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Sorry guys, I'm not active here as I used to be as my enthusiasm is dying out. I only use Windows 7, it's easier to configure and cleaner than Windows 10, and I stil pull 5-6 hours with battery power on iGPU, power saver mode, lowest brightness, alienfx off.
