M17xR5 with Quadro P4000M
Discussion in 'Alienware 17 and M17x' started by MrMogwai, Aug 19, 2019.
  1. MrMogwai
    MrMogwai Notebook Geek
    The problem is that official NVIDIA drivers won't budge, it states that the windows version is not compatible with the driver and it shuts off. For now I'm trying to get M4000M to run, no luck so far.
  2. M18x-oldie
    To set SG via the BIOS you would need an unlocked one.
    The "Hardware-ID", necessary to mod the driver, can be found under the device manger, right click on the graphics card, usually it is "Microsoft Standard Display Adapter", or something like this. Then go to "Details" --> "Property".
  3. MrMogwai
    So... after a little more struggling it seems that the machine doesn't recognize any other discrete card but the stock GTX 765M. Can anybody post the relevant nvdmi or whatever the file is called in this iteration? Every driver I've tried (for the M3000M and M4000M) says Windows version not compatible either/or No relevant hardware found, with the second message being far more prevailent.
    Got the BIOS unlocked (A16+) and even returned to factory settings (after a little tinkering in the BIOS it decided that I don't have a boot sector, after default RAID0 - which wasn't the case - was changed to AHCI ^^' )
    It is set in SG mode, but all I get is Default Microsoft Display.
  4. Rengsey R. H. Jr.
    Give us a screen shot on the gpu device info.
  5. MrMogwai
    Details for Quadro M3000M.
    Taken from Device Manager:
    Device PCI\VEN_10DE&DEV_13FA&SUBSYS_05AA1028&REV_A1\4&d590a51&0&0008 had a problem starting.
    Driver Name: display.inf
    Class Guid: {4d36e968-e325-11ce-bfc1-08002be10318}
    Service: BasicDisplay
    Lower Filters:
    Upper Filters:
    Problem: 0x1F
    Problem Status: 0xC01E0438
    Let me know what other detailed info you may require.
  6. MrMogwai
    Finally! My P4000M has arrived, as well as the 3D screen (full HD 120Hz instead of the 900p 60Hz it had), so now it's time to finally get working. Will keep you posted on the process
    M18x-oldie likes this.
  7. MrMogwai
    As usual a problem occurs - need to switch from LVDS to eDP, so I need a cable for that... Anyone knows where to get it for cheap? Except AliExpress and others?
    Or if any other model of the cable will fit? Got my eyes on Dell XPS cable, but not sure about dimensions
  8. ll_r1d0_ll
    ll_r1d0_ll Notebook Consultant
  9. MrMogwai
    Anything in Europe? Almost 70 bucks with shipping is kind of an overkill :/ if nothing shows up I guess I'll order this one though. I'm still waiting for a supplier here in Poland that said it may be available on Tuesday.
    Anybody knows if a cable from other Dell laptop is long enough to support it?
  10. ll_r1d0_ll
    it is supposed to work as long as the connector and every single thing is same as original DELL ones... I Have repalced many LVDS cables and all of them worked ..never made me search for original one ... just some 3rd party cable makers
