M17XR4 GTX 675m power throttling at 63 c..??
Discussion in 'Alienware 17 and M17x' started by brajesh143, Jul 31, 2013.
  1. brajesh143
    brajesh143 Notebook Guru
    Hi my gtx 675m is throttling at 63 c i tried modded bios both from http://forum.notebookreview.com/alienware-m17x/656685-guide-flash-your-gtx-580m-gtx-675m-r3.html
    0.87v vbios: 675m.rom
    0.92v overvolted vbios: 675m92v.rom
    still using 0.87 v bios its the same throttling at 63 c my core clock comes from 725 (overclocked in msi afterburner) to 450 sudden drop in fps !!!
    using 0.92 v bios its throttling at 63 c but my core clock only comes down from 725 to 620 !! not significant drop in fps but its there !!
    I have updated my bios to A12 still the same plz any way to fix this throttling ?? also i am unable to overclock it in nvidia inspector the clock meter is greyed out !!
  2. MickyD1234
    MickyD1234 Notebook Prophet
    Hi, this one fixed it for me. It matches P0 and P1 so the power throttle has no effect. I do not recommend the 0.92v one - it has burned cards. Also I have no idea of the source of this file so as usual - AT YOUR OWN RISK!
    You can use nvidiaInspector to up P1 to the same overclock as P0 and the voltage will not drop like it does in the original vbios.
    P0=full speed. P1=first throttle and low usage clock.
    HTH ;)
    Edit: Best OC I can get with stock voltage is around 715. After that I get flashing dots, kinda like snow. I know it's just the luck of the draw as on my 580 I could get 740 without any problems.
  3. brajesh143
    thanks a lot will try it out now
  4. Alienware-L_Porras
    Please do and let us know how it goes.
  5. brajesh143
  6. MickyD1234
    Glad to hear it. Watch your temps with that 0.92v, I was too worried about destroying the card to try it but if it works for you that's great.
    Err everyone??
  7. j95
    j95 Notebook Deity
    Never run FurMark or Afterburner Kombustor.
  8. MickyD1234
    My card has finally screwed up. Gotta call dell to replace. Started with BSOD's and now after 5 mins gaming (in any game and with any driver) screen goes blank and fans ramp up :(
    Like I need this, in hospital right now after emergency surgery - never rains....
  9. rjtnag
    rjtnag Notebook Evangelist
    damn...
    just take good care dude
    wish you luck
  10. MickyD1234
    Thanks, at least I can still use it for NBR'ing! Till, that goes then it's a call to my dad to bring in the Latitude - Nurse! NURSE!! More morph.....
