M17xr3/r4/Ranger - Plug and Play High RPM CPU fan mod
Discussion in 'Alienware 17 and M17x' started by True Debreuil, Sep 28, 2018.
  1. M18x-oldie
    Ah ok, yes that may be possible.
    I always set 5000 rpm, after 4100 or so you don't hear any changes in the spinning sound. I always thought that they are running at the max. then.
    Striker1234 likes this.
  2. True Debreuil
    True Debreuil Notebook Consultant
    I dont notice any changes in fan speed after 5800 rpm for the cpu and 4500 for the gpu, but I think they are definitely maxing out because I don't think they could spin much faster
    M18x-oldie likes this.
  3. Striker1234
    Striker1234 Notebook Consultant
    Did you remove the PWM wire for testing?, or by Software?
  4. True Debreuil
    I didn't on my current fan, but when i was soldering the modded fan I did the pwm fan incorrectly one time but it didn't go any higher then the max speed when it was done correctly
  5. 2CPU
    2CPU Notebook Consultant
    That makes more sense to me since 100% PWM should just match missing PWM wire.
    Now the SW might not command 100%, that is different.
  6. mariussx
    mariussx Notebook Evangelist
    Just purchased one, thank you for sharing this :vbthumbsup:
  7. True Debreuil
    If someone wants to try ordering the fan with the blue sticker on it instead of the green, it may be faster too. It's from a 3rd brand.
  8. domain234
    domain234 Notebook Enthusiast
    Hi, Where can I get that fan? I have seen the green label on ebay at 300 euros, it seems a real scam to put them at that price when its real value does not reach or 10 euros....
  9. M18x-oldie
  10. domain234
    Thank you. I had been trying to get one like that for some time. Currently I have the one of the m14x r2 which I had to adapt it. This one that has linqueado seems to be plug and play. A greeting
