M17xR2 Power Supply Shutdown with AMD 8970m
Discussion in 'Alienware 17 and M17x' started by alexnvidia, Jun 30, 2018.
  1. Grant B Gibson
    Grant B Gibson Notebook Deity
    All GCN cards support Async Compute, the main feature of DX12 that allows them to perform much more efficient. The reason they are branded as 11.1 is they don't support all DX12 Features, like resouce binding (like SLI/Crossfire, except allows any two GPU's that support tier 3 binding to run together as one, here are a few interesting tidbits if you want to know more
    Explanation of mGPU vs SLI/Crossfire
    https://en.wikipedia.org/wiki/Feature_levels_in_Direct3D#Direct3D_12 Which GPU arch's support what tier
    As to question why my 8950m is 90c+? Well, the I had it terrible paste, almost none, I repasted and it runs much cooler. As well, I don't have native fan control, so I have to jury rig HWINFO64 every boot time to max out the fan speed, which is only 3400RPM
    alexnvidia likes this.
  2. Grant B Gibson
    As well, when doing the benchmark, do you notice high total power draw? (HWINFO64, maw CPU+GPU Wattage
  3. alexnvidia
    alexnvidia Notebook Deity
    Hwinfo does not report any cpu or gpu wattage for my very old laptop. Maybe it isn't supported at that time. On my R4 it does state the wattage for both cpu and gpu, which is why I can't tell how much power the cpu and gpu are drawing unless I have a power monitor on the AC
  4. Grant B Gibson
    Afterburner allows you to monitor wattage, although I heard from somebody that it was just based off of voltage
  5. TheReciever
    TheReciever D! For Dragon!
    Be sure to check the DC in Jack just to make sure its not loose or anything of that sort. Though I would put my money on a failing AC adapter.
    8970m xfire also works in that machine but you will definitely need to Mod a 330w AC adapter.
  6. Grant B Gibson
    That, or it being overloaded
  7. TheReciever
    240w wouldnt be overloaded if its functioning correctly. Even overestimating power consumption at 170w is still fine for the 240w AC Adapter and thats before considering efficiency.
  8. Grant B Gibson
    170w+30w for other devices, and thats assuming the GPU isn't going above 100w, but yeah I agree with you. My 180w seems to be at the limit with a 75wGPU+40wCPu
  9. TheReciever
    Then you factor in efficiency (typically 80%), dont use software for determining power draw, they are practically worthless for getting accurate measurement of power draw.
  10. Grant B Gibson
    Welp, its the best I can do
