M17xR2 : bios update problem????
Discussion in 'Alienware 17 and M17x' started by cpaqf1, Jun 18, 2010.
  1. M17xR2
    M17xR2 Notebook Enthusiast
    Yes. BTW, do you have crossfire 5870s ?
  2. cpaqf1
    cpaqf1 Notebook Evangelist
    single 4870
    btw, after I remove the usb drive and press "any" key, it just boots to windows... lol
  3. 2002_Viper_GTS_ACR
    2002_Viper_GTS_ACR Notebook Evangelist
    Be careful with messing the bios to much.
  4. M17xR2
    try the bootable cd option, just replace the a02 version withthe a05 version and it will work fine.
    I noticed a05 has no option for a boot cd, but a02 does.
  5. cpaqf1
    pff.. sorry guys, still having problems, I burned the new bios, it boots but then it says Bad command or file name [File: A:\autoexect.bat line 43]
    any ideas ?
    edit:
    when I modify the iso from a02, do I only swap the .ROM file being the bios ? do I rename it ?
  6. M17xR2
    Why not try to revert to a02 again, its still offered on dells website (doing it through windows)
    after that goes smooth, try the a05 again. (through windows)
  7. cpaqf1
    ok went back to a02, worked fine,
    a05 stuck again...... @ block 33
  8. cpaqf1
    so rebooted pc, a05 is installed. this is so weird, what should I do next ? I honestly dont like messing around with the bios so maybe I should just stick to A02, the only reason why I really wanted A05 is for the Virtualization.
  9. AtolSammeek
    AtolSammeek Tokay Gecko
    can you boot into the bios with the f2. When I had a issue I had to redo my raid. And and I boot up into windows.
  10. cpaqf1
    yes absolutely, A02 and A05 both work perfectly
    as I said, when I flash A05, it gets stuck @ block 33, but as soon as I reboot the pc. It's updated and Virtualization is available.
