M17xR2 : bios update problem????
Discussion in 'Alienware 17 and M17x' started by cpaqf1, Jun 18, 2010.
  1. cpaqf1
    cpaqf1 Notebook Evangelist
    Hey there,
    I just downloaded the A05 bios for my r2. I launched the update program and the pc froze while "programming the 36th block". So I wait 15 minutes... nothing changes. I take out the battery to turn off the pc, turn it back on, no problems, A05 is installed. So then I decide to retry the update in case it didn't complete properly, and then same thing but at block 33.
    laptop stills works normally and A05 is installed.
    Anyone understand what's going on ??? is the bios successfully installed or what ?
    thanks
  2. Aikimox
    Aikimox Weihenstephaner!
    Did you flash it from Windows? If yes - burn the program to a CD/DVD/USB, boot from it and flash from DOS.
  3. mfractal
    mfractal T|I
  4. Aikimox
    That's one of the best "bad BIOS flash recovery" guides I've ever seen.
    Wasup Bro? :)
  5. mfractal
    mfractal T|I
    @cpaqf1 any luck?
    On a side note, having a bios update go bad is damnnn scary!!!
  6. cpaqf1
    @ Aikimox, yes I did it from windows
    so you guys are saying the update actually failed eventhough everything works perfectly ?
    how exactly do I flash it using a cd though ? can anyone tell me ?
    also, thanks for the replies.
  7. M17xR2
    M17xR2 Notebook Enthusiast
    The same software will allow you to make a 'crisis disk' and that disk can be a USB drive. Try that before doing the cd burn. I noticed the CD burn option exists in a02, but I cant find it in a05. I am sure you can just move the a05 bios file into the a02 program and it will make a bootable a05 disk for you, but I didnt bother.
  8. cpaqf1
    ok guys so I made the usb drive and booted from it.
    It says Flash crisis recovery disk
    Remove and press any key.
    I did that but then nothing happens.. am I doing it right ?
  9. M17xR2
    now you have to BOOT to it. You created it just fine, but now you need to use it on a boot, boot to it NOT the HDs.
  10. cpaqf1
    yeah thats what I did, it's first in the boot priority.. thats what you mean right ?
