M17x R4 and WX 7100 driver/detection issues
Discussion in 'Alienware 17 and M17x' started by SMGJohn, Jul 15, 2018.
  1. 2CPU
    2CPU Notebook Evangelist
    Would that HP dreamcolor 4k support future upgrades like to 1070? Or should I try to get the 120hz 1440P?
  2. SMGJohn
    SMGJohn Notebook Evangelist
    As long as the GPU can output to 4k then yes, when using eDP displays you usually just want to run PEG mode which is dedicated GPU only, your integrated wont be available with this use but frankly you gain 10 to 15% more performance by doing PEG.
  3. Rengsey R. H. Jr.
    It will work in R4?
  4. 2CPU
    Seems that panel has mounting tabs instead of the side holes?
    DP/N: 2DK4K 02DK4K
    vs.
    18J1G
  5. SMGJohn
    WX7100 and Rx 480 MXM do not support 120Hz eDP Displays, but supports 60Hz eDP in PEG mode on the Alienware M17x R4
    Ironically you can also OC your 60Hz display in PEG mode mine got 100Hz easily.
    You can however output up to 144Hz through the mini DisplayPort.
    This most likely firmware issue on Dell side as the card clearly will do 120Hz and more just fine also the Samsung 700G7A laptop from 2011 does 120Hz on 6970M and 7970M, yes MXM.
    Asus laptop with BGA Rx 580 also does 120Hz through eDP.
    The issue is with Dell not allowing AMD to work with any eDP 120Hz screens, I hope that clarifies stuff for many in the future who will attempt to use WX7100 or Rx 480 in Alienware.
    eDP and PEG is vastly better experience as the card is treated as a desktop Rx 480 with vBIOS flash giving you access to all desktop features like ReLive and more. I will attempt custom vBIOS for overclocking at later date and post the results.
  6. Rengsey R. H. Jr.
    I have proved this already.
    I ran 120hz EDP PEG with the WX 7100
    The RX 480 will not.
    Both tested in R4.
  7. SMGJohn
    If anyone needs help with finding CORRECT eDP panel for the M17x R4 you need Wedge (PCBA Bent, Depth ≥5.2mm) and reverse signal position make sure its 40 pin connection, these panels are hard to come by SHARP, LG and Samsung make them panelook has poor information on these panels so you need to do some digging I will post links and info in a new thread once I worked out everything on my WX7100 upgrade
  8. Reciever
    Reciever D! For Dragon!
    Just bought a wx7100 for 250 usd for my Ranger, hoping it all works out...
  9. Rengsey R. H. Jr.
    Nice, from where?
  10. Reciever
    ebay, might be from the same seller you bought from.
    Only thing he ever sold was the same GPU for 300 OBO of which sold at what ever the offer was lol
