M17x R4 and 1060 blackscreen with cursor issue
Discussion in 'Alienware 17 and M17x' started by SMGJohn, Sep 14, 2018.
Tags:
  1. SMGJohn
    SMGJohn Notebook Evangelist
    I been trying for almost a month to get the 1060 working in the M17x R4 to no avail, tried 37 drivers from nVidia from the first one to the last ones for 1060.
    The card runs in SG mode, full GPT partition for both W7 and W8.1 tried every muxing setting in unlocked bios to no avail.
    Had same issue on the Clevo P150 but that was fixed by using different drivers.
    The laptop boots fine with the GPU, recognised in BIOS everything suggest it should work.
    Except after installing the driver.
    I have LVDS monitor, makes no sense that the card would work on the P150 with optimus but not on the Alienware when WX7100 worked just fine which is also eDP card only.
  2. Danishblunt
    Danishblunt Guest
    Clevo notebooks translate eDP signals to LVDS via a converter chip. So yes, it makes sense.
  3. SMGJohn
    First time I ever heard of that, then it all makes sense. But why is the Alienware working with a Rx 480/WX 7100 then? This GPU should be eDP only as well.
  4. Danishblunt
    Danishblunt Guest
    https://www.paradetech.com/products/ps8625-dp-to-lvds/
    This is used for CLevo P1xx notebooks, hence pascal etc. works with optimus.
    As for the whole Rx 480/7100 working in Alienware, I don't exacly know.
    Maybe the card does support LVDS, I couldn't neither confirm or deny wheter or not polaris does support LVDS. It never has been specified, and considering it's still the GCN architecture I wouldn't be suprised if it does support LVDS for some reason.
    However, same can be said for alienware, when turning SG on, you also convert eDP signals to LVDS, however, when going for SG + eDP card, you need to be on Windows 8.1/10 and turn UEFI completely on.
    -> UEFI-> on
    -> Secure boot-> off
    -> Load legacy option rom -> Off
    Then try again, it should wotk in SG mode on alienware as well. Eurocom tested and confirmed it.
  5. ssj92
    ssj92 Neutron Star
    I'm running a 1060 perfectly fine in SG mode in an Alienware M18x. 1060 is eDP only. The iGPU converts the eDP signal (thanks to optimus).
    Are you running the 120hz display or 60hz display?
  6. SMGJohn
    That is the problem, I have done exactly this and yet it only shows a blackscreen, Windows 7 will only run in software rendering on GPT, I have dual boot of W7 and W8.1 and even if I go full UEFI on W8.1 it just wont work its puzzling me, I read literally every post on the forum about installing the 1060 in the Alienware.
    Which BIOS are you using on yours? Is it unlocked? Eurocom specifies A12 BIOS for the Alienware M17x R4 but as I recall I did try the A12 and it did not work. And I am using the 60Hz monitor, if I have to use the 120Hz I am just going to sell the Alienware, the entire point of getting it was the RGB LED screens, those are only LVDS though
  7. ssj92
    ssj92 Neutron Star
    I'm on M18xR2 with A11 unlocked. For M17xR4 you should be on A11 unlocked as well. If your A12 is unlocked then it shouldn't matter. I just didn't know A12 got unlocked.
    The M17xR4 does not have an RGB display. Only the M17xR2 offered an RGB display. The M17xR3/R4 are WLED displays. The whole point of the 120hz on M17xR4 is to have support for cards like 1060 in PEG mode.
    Try to do this:
    1) https://mega.nz/#!suJ1QYYI!bBKDBtwuxPhlt_GnlrNOOvpl-EnqIjR9LLjb4X9Ir7U
    2) http://us.download.nvidia.com/Windows/399.07/399.07-desktop-win10-64bit-international-whql.exe
    Extract the ZIP file. You need to boot using "disable driver signature enforcement" and run the nVidia installer.
    setup.cfg goes in: C:\NVIDIA\DisplayDriver\399.07\Win10_64\International
    nv_display.inf & nvdmi.inf goes in: C:\NVIDIA\DisplayDriver\399.07\Win10_64\International\Display.Driver
    SMGJohn likes this.
  8. SMGJohn
    Is better to just get the eDP display and run the GPU in PEG mode because Enduro and Optimus has always taken away 10 to 25% performance, a 60Hz eDP display cost nothing and the cable is cheap on Taobao but if you are in a hurry, 3 times the price on eBay but quicker delivery.
