M17X R4 - 980m - Throttling Research and Workaround
Discussion in 'Alienware 17 and M17x' started by Schurke, Jan 16, 2016.
  1. mariussx
    mariussx Notebook Evangelist
    Hi, Schurke
    It's 359.00 with J95 modded inf file and slv7 vbios (84.04.22.00.20) in a dedicated mode. I am trying dedicated only for now to see if my screen is still getting EDID corruption, since it seemed easier to get it than using Optimus mode.
  2. Schurke
    Schurke Notebook Consultant
    And are you experiencing throttling under heavy load or is that combination working on your rig? If no throttling, are you using any special steps to get there (like J95's state matching technique etc)? (Sorry for the storm of questions - piqued my curiosity now)
  3. mariussx
    Nothing whatsoever really :D Just DDU all the graphics drivers and installed the modded driver as usual. No matching P states or anything at all, I just set the 3D mark to maximum performance in nvidia control panel - my GPU never throttles (got it from German gaming laptop re-seller); if it does at any point - I just repeat DDU and driver reinstall. When overclocking the GPU I am trying to use the lowest voltage possible for the benchmark not to crash. And of course I only use those clocks for the benchmark to see if the latest drivers are any better than previously released. Clocks in games are either stock or slightly higher if I need some extra performance.
    Temps and no throttle clocks below:
  4. Schurke
    That makes sense - it sounds as though you maintain that fresh install state for as long as you can, then just re-install the driver if you lose it. Not the worst thing. I'll give that a try for a bit and see how long it holds between re-installs (given that I use my M17X as a laptop - in and out of my bag, on and off the wall charger).
  5. mariussx
    Edit, just tried 3d mark 11:
    http://www.3dmark.com/3dm11/10817423
    Well, it stays in no throttle state for months... The only time GPU start to throttle is after new driver install sometimes, when I have to re-DDU again (sometimes even twice - it would throttle again, so DDU and re-install again etc) and then it's back to no throttle. I forgot to mention my PSU is 330W (upgrade over original 240W, which came with 680m at the time). If you are using 240W PSU, I believe that is your main issue with throttling... R4 does not need any mods for the PSU, genuine DELL PSU (Dell part number XM3C3) works perfectly fine. :) I my case, the laptop stays plugged in most of the time as well, I almost never use it on the battery.
    Solo wing likes this.
  6. Solo wing
    Solo wing Notebook Consultant
    I'm using driver 352.84 on windows 10, 120Hz display, and a 240W PSU. CPU is OC to 4.3 GHz. I think a 330W PSU is a must.
    After installing the XM processor, I started getting driver crashes on SVL7's vbios (1.00v). Now testing with Prema's vbios (1.062v).
  7. woodzstack
    woodzstack Alezka Computers , Official Clevo reseller.
    So, you and @Solo wing support my max power draw theory, BUT - the OP still has pretty awesome performance regardless.
  8. Schurke
    @woodzstack , @Solo wing , @mariussx - Do you guys have access to power draw measurement tools (like a KillAWatt or similar)? Tests at my place showed most of the Firestrike benchmarks not even cresting 200w (and underclocking the CPU I was able to get down to about 165w draw and still was throttling after leaving the "fresh install" state). I'm wondering now if my readings/tool are off and if any of you can verify... Because if the draw is sub 200w, a 330w PSU shouldn't be much more than a placebo... right?
  9. Solo wing
    @Mr. Fox did a power draw test of a single 980M, it never went below 270 during the test:
    Mr. Fox likes this.
  10. woodzstack
    so 10-15% OVER the 240W PSU.. minimum. interesting. Well, sure puts things into perspective.
