M17X R2 screen blinking i need your help
Discussion in 'Alienware 17 and M17x' started by AlienM17xR2, Jul 10, 2020.
  1. AlienM17xR2
    AlienM17xR2 Newbie
    Hi everyone here's my my problem and i need your expérience(sorry for my english i'm just french...) :
    I own an Alienware M17X R2 and i have a trouble with my screen, start fine, Windows fine, but after few minutes screen start to blink and then the screen is green, blue, red, (RGB)
    I've plug on another screen to test if the trouble is from GPU, everything work fine on another screen but laptop screen blink (RGB) constantly..
    I have an AMD Radeon 5870 HD mobility series
    I've change several time screen cables (bought on eBay) the problem is constant...
    I've repast CPU, GPU problem is constant
    The screen have an inverter inside
    So the question is how to diagnose the problem ?
    I have plan to buy another AMD 5870 and hope the problem is over.
    But if it not what can i do to solve it ?
    Thanks for your Time, thank for your help
  2. Crustieraxe01
    Crustieraxe01 Notebook Consultant
    Seems like a possible faulty GPU. Have you tried changing it to see if behavior continues?
