m17x-r2 cant enable wireless
Discussion in 'Alienware' started by cpaqf1, May 1, 2010.
  1. cpaqf1
    cpaqf1 Notebook Evangelist
    Hi there guys, as the title states, I'm not able to enable the wireless card eventhough its installed... any ideas ?
    thx
  2. mfractal
    mfractal T|I
    Well, what have you tried? What do u mean enable it? Did u maybe disable it through the media button? Can you see it in device manager? More details please.
  3. cpaqf1
    pretty much everything, I checked the media button setting and yes its in device manager. I also tried a usb wireless card and it does the same thing.. any ideas ?
  4. mfractal
    mfractal T|I
    What happens ? You don't see wireless networks? Neither with the built in card nor with the USB wifi?
  5. cpaqf1
    http://tinypic.com/r/29ny0qw/5
    and I cant enable it
  6. TheCodeBreaker
    TheCodeBreaker 7H3 1337
    There are a few things that can be causing this. Have you tried going in the bios under the advanced option tab and enabling it? you do that by clicking the f2 button when seeing the splash screen, then the right arrow when in the bios, and you would see a few options, amongst them is Wireless Network.
  7. trikster
    trikster Notebook Evangelist
    Stealth mode enabled? On my R1, whenever I would go into Stealth mode (by accident) I would lose wireless and my battery would not charge unless the laptop was off.
  8. wacdag
    wacdag Notebook Consultant
  9. cpaqf1
    thanks for all the help so far guys.. ive tried pretty much everything and it still doesnt work.. ;\
  10. mfractal
    mfractal T|I
    Do you see it in device manager as disabled? I still think it's the media buttons fault btw.. Have u tried uninstalling command center and reinstalling it ?
