M17x R2 8970M Brightness control?
Discussion in 'Alienware 17 and M17x' started by Raidriar, Nov 13, 2017.
  1. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    I installed my Clevo 8970M into my M17x R2 tonight, and it is working with native fan control, but brightness is broken, stuck to max brightness. adjusting slider does nothing. any fix? Running windows 7
    Single 8970M bench with a 940XM
    https://www.3dmark.com/3dm11/12488143
  2. Danishblunt
    Danishblunt Guest
    Did you try other drivers just to check?
  3. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    You know, I went ahead and tried the past several re-live drivers, they all stuck my brightness at maximum. So i tried the final catalyst 2015 driver before they changed to crimson, and brightness works. Will do some investigating....
  4. goodstone
    goodstone Notebook Consultant
    I remember this on my R2 when upgrading to windows 8. You need to change registry keys. Unfortunately I cannot remember which ones. I will try to hunt down .
  5. goodstone
    Found it. Try this might work.
    HKEY_LOCAL_MACHINE> SYSTEM> ControlSet001> Control> Class> {4d36e968-e325-11ce-bfc1-08002be10318}> 0000> KMD_EnableBrightnessInterface2 to 0
    Reboot!
    TruenoG7 likes this.
  6. andrewff2
    andrewff2 Notebook Evangelist
    Hey there man!!! I have one 8970m too and w10+amd driver are killing me.
    Did you find any native way to make the brightness work? or shoul i go to old drivers as well? do you recommend any old driver version???
  7. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Nope, never found a resolution with newer drivers.
  8. screemex
    screemex Newbie
    Hi, i'm looking for working vbios 8970 non enduro for aw m17x r2. I have one but clocks stop at 450/300
  9. screemex
    screemex Newbie
    Hello, I am looking for a working vbios to 8970. My problem is that the clocks freez at 450Mhz and the memory at 300Mhz
