M15x work with i7 820qm?
Discussion in 'Alienware M15x' started by Spiderdog, Sep 4, 2012.
  1. txsizzler
    txsizzler Notebook Geek
    The only thing I can think of is to do a power drain (remove the laptop battery, and hold down the power button for 60 seconds), remove the CMOS battery (which you have done already), make sure the new processor is seated correctly without bent pins, make sure you have the thermal paste put on correctly (just a small dab on the processor), and the heat sink put on top of the processor with it fully in contact with the processor/thermal paste.
    Most likely in this case, its a problem with how you have the processor seated, or a case of a bent or missing pin. Take the processor out, and check it thoroughly for bent or missing pins. Be sure to install it correctly with all pins being seated in their respective holes. Be sure to turn the screw to have the processor locked down in the socket.
    Make sure your memory is locked in the upright position too. Otherwise, I am tapped out of ideas, as you have already installed the latest BIOS.
  2. dave_n_charity
    dave_n_charity Newbie
    Having just gone through this (possibly from the same seller as you), I can tell you that this is indeed the problem. That "ES" stands for "Engineering Sample." These chips are made to be abused, in order to find out just how much it can handle. They are not made for, and will rarely work in, consumer computers. Moreover, it isn't technically legal to sell them. Your 820QM ES will never work in your M15X, or any other laptop you get. Return it and take the OEM 720QM instead.
  3. extide
    extide Notebook Deity
    Actually the ES chips generally work fine. They are mostly used for platform validation by Intel's partners. I know people have ran ES's in m15x's before, also.
  4. khetik
    khetik Notebook Deity
    I agree with the above post. To say that an ES chip will never work in a M15x is well and truly false information. There are countless people using ES chips, namely the 920xm, in their M15x's (nbr members included). Its the same with anything you buy, there is always the odd chance that you may receive a bad/faulty item, or something may go wrong during installation. Worst comes to worst try for a refund/exchange with the seller/retailer you bought it from after exhausting all possible options.
  5. otosan
    otosan Notebook Consultant
    Mine is working well with 920XM ES version..., even running on 3.0Ghz on all core
  6. ryguy12290
    ryguy12290 Notebook Enthusiast
    After all that I would suspect faulty CPU.
    I also had a friend who accidentally got Thermal Paste in the socket when he installed his CPU and it messed up his system =/
  7. junglebungle
    junglebungle Notebook Evangelist
    CPU is obviously faulty, send it back.
