M15x wont power on after installing alien fx
Discussion in 'Alienware M15x' started by Clarent, Jan 17, 2020.
  1. Clarent
    Clarent Notebook Enthusiast
    Help my m15x dies after installing the alienfx with windows 10, before its goes black it said that the alienfx has been upgraded to version 1.0.0 to version 1.30 then turn to black screen, It still can power on a litte bit but the fan stop spinning after i power it up.
    Does that means im motherboard is bricked? And what is the solution to fix this?
  2. blazeghost
    blazeghost Notebook Guru
    Does your computers boots into bios at least or just stays with a black screen? If so, check your SCROLL CAPS NUM leds to see if they blink for any error codes info.
  3. Clarent
    It doesnt boot to bios, but the alien fx glow within 1-2 seconds, alongside the fan then the machine go silent, the all lights turn black, all of its fan stop spinning as well
    it starts like this.
    And yes its happen when i tried to upgrade my alien fx my screen turn black and all the lights glow, i immadiately stop the power supply after the screen goes black with no sound.
    After that i connect the power supply and its end like this
    no sound no fan spinning it just dies there after failed boot up
    If it because corrupted bios or?
