m15x SD Card Slot Jam
Discussion in 'Alienware' started by ARC_Sharp, Apr 26, 2010.
  1. ARC_Sharp
    ARC_Sharp Notebook Enthusiast
    Well my sd card slot i got sumthin jammed into my sd slot and now i cant get it out is there a way to open the laptop to where i can get into where the jam is? pictures and an explanation would be VERY helpful thanks.
  2. dwend
    dwend Notebook Evangelist
    Micro SD cards don't fit, lol
    But try sticking a sowing needle in there and then shaking it, with it off and no batteries or power of course. 2 would work better and then using them as like chop sticks.
    I accidentally stuck my SD card into the expansion slot cause I was not paying attention, and that is how I got it out.
  3. ARC_Sharp
    lol i that that with some toothpicks but unfortunately that only stuck the thing in farther :O then again the expansion slot is like twice the size of the sd slot
