M15x internal fan mods?
Discussion in 'Alienware M15x' started by Raidriar, Dec 21, 2016.
  1. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    possibly number of blades, curvature of blades, etc.
    MZWiZard likes this.
  2. King of Interns
    King of Interns Simply a laptop enthusiast
    7.7 cfm still ain't enough ;)
  3. deadsmiley
    deadsmiley Notebook Deity
    I purchased three of these. They were 5.5 CFM fans so I am asking for a refund. Bleh...
  4. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    As did I, i told them I wanted a 7.7 and they said they didn't have any....the hunt continues.
    deadsmiley likes this.
  5. deadsmiley
    They refunded and didn't ask for them back. Probably because it would cost them money to return them.
  6. TheReciever
    TheReciever D! For Dragon!
    I ordered the 10.4 CFM fan from the m14x R2 for my y510p model number
    0XN0G5
    I culdnt risk the larger m17x R4 GPU fan, as its slightly larger I believe
  7. Raidriar
    Raidriar ლ(ಠ益ಠლ)
  8. bartuc66
    bartuc66 Notebook Enthusiast
    I have no idea where the extra rating (5.5 to 7.7) comes from . I ordered the stock Delta version. I then compared it to the AVC fan.
    There are no geometric differences (design of blades, # of blades, pitch, etc) between the two fans. They are also the same size (diameter, thickness). The only two differences between the fans are: 1) the Delta's motor is noticeable larger and 2) the Delta's shaft of Delta fan is noticeably thicker (actually the same diameter size as the M17x R2 fan that I purchased earlier).
    Therefore, the only increase of the CFM rating can come from the maximum rotation speed of the fans. I used HWinfo64 to max the RPM of the fans. The AVC spun at 4,500 rotations per minute while the Delta spun at 5,000 rotations per minute. If there is a better method, please let me know so that I can perform a better test.
    With that said (for everyday usage), I have not noticed any significant difference between the CPU temperatures using the two "different" fans. I still plan to get the M14x fans.
    *I would also like to add, that the AVC CPU and AVC GPU Dell stock fans are the exact same. These two Alienware M15x fans were completely identical. The only difference between the two is the max speed that the motor is capable of spinning up to.
    MatsueMaiku likes this.
  9. TheReciever
    Hey guys,
    So I have run 3 tests, 3 times each with my stock fan, I will crunch those numbers tomorrow.
    The tests I have run are just what I have on hand.
    1. Rainbow Six - Siege
    2. Company of Heroes 2
    3. AIDA64
    I just modified the y510p to accept the m14xr2 fan, Its moves significantly more air than stock thats for sure. It even handled my 755m overvolted at 1.2v 1350core and 4700mq @ 3.4Ghz 4 core turbo.
    I will be running the same 3 tests, 3 times each and getting the numbers to get an average and ill let you guys know the difference that shows up in my data.
    It would be really helpful though, personally, if anyone can link me to projects of similar nature though. Something with before and after data, pictures are a plus.
    I would be using them for references in my project in University. Anyways ill report back when I have the numbers and such.
    (I know its not an alienware laptop I have, but I figure you guys would still be interested in how it works for people)
  10. TheReciever
    Hey everyone, I have finally got this stuff done.
    I actually finished it a couple of days ago but right at the tail end of it, Excel crashed on me and I had to work up the will to start it over.
    I have added it as an file, its a bunch of data, I havent made it into a bar graph as I still have to figure out how to do that with the applications I have (or can get online)
    I ran most things 3 times, and the blue is the AVG, Highest reported temp, and Lowest reported temp summarized in blue for each section which is bolded.
    My fan control is locked so I have stock fan curve or max fan (via cutting control wire for the fan) With the stock fan curve it actually resulted in worse temps in AIDA64 but forcing fan speed to max really reaps the benefits. I just ordered some Grizzly-C liquid metal to see how much of an improvement Ill get from NH-T1 that I usually use.
    Let me know what you guys think, this is using the M14x R2 Fan.
    bartuc66 and deadsmiley like this.
  11. MatsueMaiku
    MatsueMaiku Notebook Geek
  12. bartuc66
    I have been wanting to try out one of the fans from the new Alienware 15 models (R2 and/or R3). They definitely have more than double the amount of blades compared to the stock M15x fan. Would anybody happen to know the dimensions of that fan? I've been asking all the sellers on eBay, but I have yet to get a reply. I don't want buy yet another fan that is too large for the M15x.
    edit(11/2/2017): So I ended up ordering an Alienware 15 R3 fan. It will not fit in the M15x. The fan's diameter is too large.
    Clearik likes this.
  13. MatsueMaiku
    That's good to know, Bartuc66. Thanks for the info. I haven't had any time to test mine out yet.
