M15x GTX970m Nvidia Driver modded .inf
Discussion in 'Alienware M15x' started by blazeghost, Mar 28, 2019.
  1. LukYreM
    LukYreM Newbie
    So in this specific case the pc freezes and I have to restart in safe mode and use DDU and thus retry, no BSOD
  2. LukYreM
    LukYreM Newbie
    edit
    I just tried again by installing the drivers only, no physx and hd audio and indeed I have a blue screen with the smiley "no happy"
    I will try other section.
    The inf of blazeghost indicates section 44 I will try another ... :(
  3. LukYreM
    LukYreM Newbie
    edit 2: same result with others sections 45 and 46
    so, that's not the problem
  4. LukYreM
    LukYreM Newbie
    I'm wondering if there isn't a problem with the SG or PEG which can be activated with Fn F7 or BIOS Modded.
    And moreover my battery does not work any more so it is constantly on sector and suddenly it does not pose a problem whatsoever ....
    thank you for your help anyway, i appreciate a lot
  5. Zero 1
    Zero 1 Notebook Consultant
    that leads me to believe there is actual issues with the card itself :/
  6. Zero 1
    gah no one has a modded bios for the m4000m ill need to unlock the tdp myself i suppose . its hard with my bad eyes but i think i can do it
  7. sL1pKn07
    sL1pKn07 Notebook Enthusiast
    i have installed the 471.68 thought ncvleaninstall+manual step
    - download the drivers manually
    - run nvcleaninstall and select the downloaded driver
    - select the install components: driver, physx and HD audio., click next and wait the unpack
    - select this in the next screen:
    this option is optional. i do it for avoid problems with games
    - BEFORE click next, go to the nvcleaninstall temporal directory:
    C:\Users\>you_user<\AppData\Local\Temp\NVCleanstall\Display.Driver
    - if you are familiar with Patch/Git (apply) program, here a patch file:
    Code:
    diff --git "a/nvdmi.inf" "b/nvdmi.inf"
    index 03caf4a..f54e505 100644
    --- "a/nvdmi.inf"
    +++ "b/nvdmi.inf"
    @@ -241,6 +241,7 @@ HKR,"Global\NVTweak",NvCplEnableSRS1564,%REG_DWORD%,1
     %NVIDIA_DEV.13D7.0688.1028% = Section044, PCI\VEN_10DE&DEV_13D7&SUBSYS_06881028
     %NVIDIA_DEV.13D7.0708.1028% = Section045, PCI\VEN_10DE&DEV_13D7&SUBSYS_07081028
     %NVIDIA_DEV.13D7.0709.1028% = Section045, PCI\VEN_10DE&DEV_13D7&SUBSYS_07091028
    +%NVIDIA_DEV.13D8.02A2.1028% = Section044, PCI\VEN_10DE&DEV_13D8&SUBSYS_02A21028
     %NVIDIA_DEV.13D8.05AB.1028% = Section043, PCI\VEN_10DE&DEV_13D8&SUBSYS_05AB1028
     %NVIDIA_DEV.13D8.0685.1028% = Section044, PCI\VEN_10DE&DEV_13D8&SUBSYS_06851028
     %NVIDIA_DEV.13D8.0688.1028% = Section044, PCI\VEN_10DE&DEV_13D8&SUBSYS_06881028
    @@ -32240,6 +32241,7 @@ NVIDIA_DEV.13D7.0685.1028 = "NVIDIA GeForce GTX 980M"
     NVIDIA_DEV.13D7.0688.1028 = "NVIDIA GeForce GTX 980M"
     NVIDIA_DEV.13D7.0708.1028 = "NVIDIA GeForce GTX 980M"
     NVIDIA_DEV.13D7.0709.1028 = "NVIDIA GeForce GTX 980M"
    +NVIDIA_DEV.13D8.02A2.1028 = "NVIDIA GeForce GTX 970M"
     NVIDIA_DEV.13D8.05AB.1028 = "NVIDIA GeForce GTX 970M"
     NVIDIA_DEV.13D8.0685.1028 = "NVIDIA GeForce GTX 970M"
     NVIDIA_DEV.13D8.0688.1028 = "NVIDIA GeForce GTX 970M"
    if not, do it manually follow steps posted in this thread
    - After the patch applied/add manually the lines, Click NEXT button
    - Perform the installation
    after install. enter in windows with the allowed unsigned drivers boot option (if the driver is not loaded)
    for security, i do this steps for avoid windows update install new drivers:
    https://www.howtogeek.com/263851/ho...from-automatically-updating-specific-drivers/
    no forget disabe the filter if you want update the drivers, and enable again after that
    greetings
  8. blazeghost
    blazeghost Notebook Consultant
    Updated post for Driver ver. 471.68
    Enjoy.-
  9. Mana82
    Mana82 Notebook Enthusiast
    Hi,
    Just wanted to say thank you blazeghost for providng these modded inf files. I just got round to upgrading my m15x from a 5850m to a 970m and used your files for the latest nvidia drivers as of 22nd August 2021.
    Cheers!
  10. blazeghost
    Glad to hear it helped you :)
    I´ll keep posting as long as someone keeps downloading the files
    Mana82 likes this.
