M15X GTX 980M - Pls Help to modify nvdmi.inf
Discussion in 'Alienware M15x' started by DNOYA, Sep 15, 2018.
  1. DNOYA
    DNOYA Notebook Guru
    a lot of drama happened, starting from the GTX 970M arrived at my place and finally upgraded to GTX 980M.
    after more than 1 month waiting for the GTX 970M to finally arrive, this GPU is very easy to install, plag and play has nothing to modify and the performance is very good. unfortunately after I used it for 1 week GPU error and could no longer be used because of the chipset error, I finally asked for a warranty from the store, they promised to replace it but they don't have stock GTX 970M, only the new GTX 980M is available. and they can send it by express. with disability I have to add money.
    4 days waiting for the GTX 980M to arrive, I hurriedly installed it and it turned out, it didn't match what was imagined. to install GTX 980M is not only plag and play. but we have to modify the file "nvdmi.inf" and I have spent 2 days but it didn't work.
    therefore, I beg for help from my friends in this forum as fellow AW M15X fans, along with information from the HW ID and the original NVDMI file that I extracted directly from the NVIDIA driver. I hope there are friends in this group who can help.
    PCI\VEN_10DE&DEV_13D7&SUBSYS_02A21028&REV_A1
    PCI\VEN_10DE&DEV_13D7&CC_030000
  2. Danishblunt
    Danishblunt Guest
    Enjoy
  3. DNOYA
    DNOYA Notebook Guru
    Hi Danishblunt
    thanks for helping me to modify the .INF just updated to you the result still fail
    Following the work sequence I did
    1. Enter safemode and use DDU to remove everything clean
    2. enter disble driver signature mode in a way commong promnt as a admin and bcdedit / set testsigning on and restart
    3. install the nvidia driver and finish successfully no error (399.24-notebook-win10-64bit-international-whql)
    but when i run the benchmark, i still get the msg "application has been block from accessing graphic hardware".
    when i play BT4 once the game start the screen become black but the game still running - the samethinghappen get the msg "application has been block from accessing graphic hardware".
    what do you think is the next thing I should do, need advice :(
    note:
    i use mod svf7 bios
  4. Danishblunt
    Danishblunt Guest
    If you have teamviewer you can private message me with ID and password, then I can look at it.
    DNOYA likes this.
  5. DNOYA
    DNOYA Notebook Guru
    Hi Danishblunt
    thank you for wanting to help, I will try to install window 7 and do the same thing, if in window 7. still can't, I will share ID teamview and match the time with you. I'll give you the results after it's finished
  6. DNOYA
    DNOYA Notebook Guru
  7. DNOYA
    DNOYA Notebook Guru
    finally the problem that I experienced was finished, thanks to
    Danishblunt
    who had remotely helped and shared knowledge about overclocking.
    based on the information from him the problem came from the VBIOS that I used because this vbios gave too much power, after we decided to return it to the VBIOS stock everything returned to normal
    for the record the error report from the system was :
    "application has been blocked from accessing graphics hardware"
    the behavior
    if you run game : after view second the screen went white or black
    if you run 3Dmark : after initial finish start the benchmarks the screen complatly white after sometime its went error or frezee.
  8. Diego Teixeira da Luz
    Diego Teixeira da Luz Newbie
    Danishblunt, Hello. I have a problem with the GTX770M video card clock. It's in 405/405. Can you help me. I'm from Brazil.
  9. Danishblunt
    Danishblunt Guest
    What notebook are we talking about?
    also it only puts a load on 405/405 when gaming or is is basicially 24/7 stuck on that load?
  10. Diego Teixeira da Luz
    I'm talking about the GTX770M.
