M1530/1330 "AC power adapter wattage and type cannot be determined?" Error Thread
Discussion in 'Dell XPS and Studio XPS' started by hanime, Aug 1, 2008.
  1. hanime
    hanime Notebook Evangelist
    When I boot up my laptop, I get this exact error:
    Screenshot: http://www.hanime.net/adapter.jpg
    I recently updated from BIOS A08 to A09 if that matters. Any ideas?
  2. X2P
    X2P I♥COOLING | NBR Super Mod
    Just strike the F3 key. I have had this dozens of times on updates and clean installs with my Vostro 1500 and its not a big deal.
  3. hanime
  4. rpt2000
    rpt2000 Newbie
    I had this problem on my M1330. It really does decrease your computers performance. You will also notice that your power supply is a lot cooler as your computer is drawing less current. Your battery may not charge.
    You need dell to replace the power supply, it's a common problem so you should not have any hassle. The latest adapter is Rev A02. A Dell rep in the USA suggested on a forum to ask for a 90w adapter so the problem does not recur.
  5. XPSboy
    XPSboy Notebook Evangelist
    i think that's software conflict....maybe your new installed software is not playing with the other software installed. (ex. NVIDIA, etc.)
    i got 90W Rev04 adapter, still i experienced that problem just once.....i just rollback my previous snapshot and all of my faulty latest installed software is gone and that AC power adapter problem never pop up.
  6. PvD
    PvD Notebook Consultant
    Actually that has nothing to do with software, if you go to bios and under AC Adapter it will be listed as unknown, If you have another ac adapter to test with do it, if you dont call Dell they will replace the ac adapter for you, If you have another ac adapter to test with, and the other ac adapter does the same the Motherboard has to be replaced (Including Video Card, which is soldered to the Motherboard)
  7. yasdaz
    yasdaz Notebook Evangelist
    My apologies, PvD; I am not clear on what you are saying. If in the bios the adaptor shows as unknown then you might have a motherboard problem? You need to test with another adaptor (if you have one around) because if it shows up as unknown you definately have a motherboard problem? Sorry, just need a bit of clarity :). Thanks!
  8. Death Ro
    Death Ro Notebook Guru
    I got the same problem on mine. However, I just continue and it charges. I don't think my performance has suffered any either...
  9. Arsenaly
    Arsenaly Notebook Guru
    just hit F3 its not a big deal
  10. derviskemal
    derviskemal Notebook Consultant
    i get exactly the same error whenever i startup.
    might have to contact dell and see what they have to say...
