M14x R1 - Refurbish Project
Discussion in 'Notebook Cosmetic Modifications and Custom Builds' started by Maxware79, Jul 9, 2020.
  1. ssj92
    ssj92 Neutron Star
    I'd love a custom painted M17xR4 but too bad shipping would cost so much :D
  2. Maxware79
    Maxware79 Notebook Deity
    Yeah, probably not worth it. I have a spare lid and frame for an R4 so I may give it a shot. I'm keen to do a flat orange/black combo soon.
  3. Maxware79
    When spray painting doesn’t go to plan.......
    ssj92 likes this.
  4. Maxware79
    The lid is looking great though.
  5. ssj92
    ssj92 Neutron Star
    What happen? :eek:
  6. Maxware79
    Not sure, maybe I sprayed it too thick. It wrinkled instantly, it was actually kind of cool. Kind of like a science experiment.
    I had to strip the paint and primer off and start again. I’ve put extra layers of primer this time and I’ll put the base coat on in light layers.
  7. Maxware79
    I'm wondering if I try red on the palmrest again or keep it black (or even white....)
  8. Maxware79
    It’s starting to come together. The lid and the frame are completely done. I decided to switch to a satin black on the palmrest after my earlier setback. It will need a satin clear coat in a few days and then reassembly can begin.
    Charles P. Jefferies and Vaardu like this.
  9. Maxware79
    Palmrest is still a few days away but the rest is all back together
    ssj92 likes this.
  10. Maxware79
    All done. It’s always good when it boots after being in a hundred pieces.
    ssj92 likes this.
