M11xR2 Battery Problem
Discussion in 'Alienware M11x' started by MasivB, Jul 31, 2012.
  1. MasivB
    MasivB Guest
    I recently just noticed that my notebook will go into Hibernate (the critical battery response) even when the battery is reading a Full Charge. I also checked the LEDs on the bottom of the notebook and there are 5 LEDs lit. This happens only sometimes now but I am concerned that it will be an ongoing issue. I have unplugged the battery and checked it out and plugged it back in but the problem still persists. Has anyone else ever experienced this? Do I need a new battery from Dell?
  2. DELL-RajeshR
    DELL-RajeshR Company Representative
    Hi MasivB,
    Welcome to the community.
    Let me first appreciate the fact that you have tried the steps yourself to resolve the issue.
    Firstly, I recommend you to do a bios update from the below link.
    Drivers and Downloads | Dell [United States]
    Kindly Verify by checking the status of battery in “Alienware command center”.
    Waiting to hear from you.
    If you have active warranty, you can contact me directly by clicking on my user name, add me as your friend, and send me the system service tag and phone # with address.
    Thanks & Regards
    Dell_Rajesh_R
    Dell Social Media Responder
    Welcome to Facebook - Log In, Sign Up or Learn More
    Twitter
  3. Alienware-L_Porras
    Adding to what my partner had to say you can also try this article from our website.
    Have you had any errors regarding the power cord? Like "This AC adapter is not the recommended one" or anything between those lines?
  4. MasivB
    MasivB Guest
    Just to be clear, you are asking me to install the A05 which says its an update for the R1, I have an R2. Just to make sure because flashing a bios can be pretty deadly.
    Never any problems with the battery, its always been perfect. I've used the same outlet for 2 years. I know these Li-on batteries tend to give out faster. I do not have an active warranty but I would either, depending on Dells replacement parts or recertification for a new warranty will either pick up from them or off a certified re seller of another battery. I know they are probably expensive so I am not sure my options yet.
    Thanks for the support. I will be trying both of these troubleshoots
  5. Alienware-L_Porras
    That BIOS is not the latest one for your machine, you can try this one for the R2 it's a Windows executable file, make sure you don't have any application open while you run it or disconnect the computer from the power while you are at it.
    If you need pricing info you can let us know by sending an e-mail with your tag, phone and a brief description of your needs to AlienwareUpgrades@dell.com, we'll be happy to help you with that. I can also give you the same information for the battery but before you do that you can try the article I sent, almost 70% of the time the only thing you need to do is to do the power cycle that is mentioned there.
  6. MasivB
    MasivB Guest
    Yeah I already have latest BIOS. I was just wondering why the Dell rep gave me a link to the R1 bios update when I have an R2...
    Anyway thanks for the fix, I havent tried it yet as I havent got time but will definatly try it out thanks for all the help.
  7. Alienware-L_Porras
    Ok that leaves us with either, an issue with the battery or the motherboard (the jack). Why not trying one of them at the time. Get the battery and if it does not work return it and get the motherboard instead.
  8. Alienware-L_Porras
    I haven't heard back from you on this issue. If you need further assistance shoot me a PM and I'll provide you all the details you need regarding this. You can also use the e-mail on the above post.
    Also just to make sure did you flash the BIOS and do the power drain?.
